Old 29th January 2022, 09:55 AM
mcs's Avatar
mcs mcs is offline
Default Wheel Bearing Help
Hello Team,
I have to replace my front drivers side wheel bearing. It makes noise at 100kph (exact highway speed here) as the inner seal has failed and it is shedding grease.
I got a new bearing with the hub pressed in, but it didn’t fit. Im wondering if the rear bearing is the same as the front? Im getting conflicting info. I specifically ordered the front bearing but perhaps they sent me a rear one? Or simply one for a different audi.
Thanks,
Mike
04 A8 - 4.2 Sport
Indigo Leather Sports Seats - Sports wheel - Sports Air Suspension
Auto Boot - Double Glazing - AMI - Solar roof
TV - Bose - Voice Control - TPMS - AFS- TINT
Power Blind, Fingerprint - Light package (in and out)
Retrofits:
OEM Auto headlights & rain sensing wipers
OEM Bluetooth phone
Bluetooth Audio Streaming
Reverse Camera
OEM Aluminium Package
Auto boot close using remote/door button
Old 29th January 2022, 10:03 AM
The bearings are different between front and rear. Front is 92mm, rear is 82mm I think. The part numbers are vexingly close - 4E0498625B for the front, 4E0598625 rear, so its possible someone just got them mixed up.
Old 29th January 2022, 07:45 PM
mcs's Avatar
mcs mcs is offline
Perfect information. Thankyou!
04 A8 - 4.2 Sport
Retrofits:
OEM Bluetooth phone
Reverse Camera
Old 22nd May 2022, 11:57 PM
mcs's Avatar
mcs mcs is offline
As a follow up,
I am still getting a vibration and noise at highway speed. It feels like a wheel weight is off but sounds like bearing noise. The vibration is felt through the pedals and remains even if the driveline is put into neutral.
I have changed;
Brake rotors and pads
Wheels front to rear (including trying the spare)
A wheel bearing
Gearbox fluid - many times (due to other leak)
front engine torque mount
ALL suspension arms
Tie rods inner and outer.
Sway bar bushes and end links.
I am at a total loss. I just want this car to be smooth like it used to be.
Do driveshafts go bad in these?
04 A8 - 4.2 Sport
Retrofits:
OEM Bluetooth phone
Reverse Camera
Old 29th May 2022, 02:08 PM
Prefferle Prefferle is offline
Originally Posted by mcs View Post
As a follow up,
I have changed;
A wheel bearing
ALL suspension arms
The CV joints can become worn but these usually start clicking when turning so that’s one symptom for the fronts. There would be a tolerance check that can be made to determine the CV wear but I haven’t a clue - not had that issue as yet so couldn’t advise on that.. Vibration on the steering (when braking only) can be a sticking front brake calliper otherwise if constant without braking it could be wheel / tyre distortion or wheel balance. - I’ve had this recently…
Not knowing what noise or how you are feeling this vibration makes it difficult to pinpoint however, vibration at speed not felt on the steering can likely be rear wheel balance or wheel / tyre distortion issue, or rear wheel bearing issue, in some cases front wheel balance or alignment issues can cause vibration and shimmy felt on the steering at around 60-65mph.
With so many bits whizzing about it can be really Frustrating to pinpoint some if these!
Please let’s know how you get on!
Regards,
Present cars
Daily driver: BMW e65 730d
Batmobile: 2006 S8, D3, 4E 5.2L V10 BSM with (loud) Miltek SS exhaust, Carbon Fibre trim, Alcantara headlining, soft close and keyless entry.
