Old 30th January 2022, 02:33 PM
Default Fuel pump?
I've had my FL D2 S8 for years. It's been super reliable and I don't beat on it.
Today, running around in town, the car stuttered and stopped.
It cranks ok, and I found that if I left it for 10 mins, it would start but only run at about 400 rpm for a while then cutting out.
No warnings came on and there's just under half a tank of gas in it.
It's been hauled off to a local-not Audi garage.
Whaddya think? I thought fuel related- maybe the pump or a fuel pump relay???
Expensive to repair?
Old 30th January 2022, 03:06 PM
Classic fuel pump symptoms. Amazon has genuine pumps silly cheap at the moment: VDO 405-052-002-001Z. Delivery is a tad vague for some reason, but probably still faster than Autodoc and 2/3rd the price.
You might want to get it recovered to an Audi specialist who will do it properly. Random all-makes garages have a habit of bodging and ruining D2 fuel pumps by fitting whatever incompatible crap their local factor has on the shelf.
Old 30th January 2022, 04:07 PM
Ronin Ronin is offline
how much fuel did you have when it happened?
Old 30th January 2022, 04:53 PM
It was just under half a tank.
Old 30th January 2022, 05:00 PM
Thanks Mikki.
Is fitting a big deal? I guess it goes in from the top, so an 'in-the-boot' job?
Is there a sensible alternative to fitting a new one? Maybe the old one is just gunked up? (although it was a pretty sudden failure with no warning signs).
My pump wasn't noisy, but I could hear it for a few seconds on each startup- as long as I paused turning the key when the lights come on.
Old 30th January 2022, 06:10 PM
Fill the car past half a tank and see if it fires up, if it does its probably the seals on the fuel pump and not the fuel pump itself
Old 30th January 2022, 06:30 PM
Thanks Ronin- I'll try that.
I wondered if it might be fuel starvation. We just come round a 90 degree right hander and gone from a steady descent to a bit of a climb.
Old 30th January 2022, 06:55 PM
Originally Posted by Simon Wallwork View Post
Thanks Mikki.
Yes, for the uninitiated. Its quite an ordeal to get it out of the tank, and then even more so to get it back in properly. If its not seated properly (or the wrong pump is used) then you run out of fuel at 1/4 tank.
Even once the housing is out (and with 1/2 tank or more there is going to be fuel everywhere in the boot unless you know what's coming), in this weather it just wants to shatter. It needs warming up so that the plastic clips come undone, then its just fiddly and annoying.
No, its dead. This is the standard failure mode.
Old 31st January 2022, 10:46 AM
Well the Master (as they call tradesmen here) has confirmed it's the pump.
New one 300 euro.....
Just hope he doesn't make a 'See you next Tuesday' of it....
Old 31st January 2022, 11:21 AM
300 euro is a total rip off you can get it done yourself for 1/2 or 1/3 of the price and I bet he won't even bother to test it properly or replace any of the o rings
