Old 31st January 2022, 12:31 PM
roberto's Avatar
roberto roberto is offline
Default S8 V10 D3 power steering pump change
anybody know how to do this, or had it done at what cost please?
new power steering pump needs fitting..
Old 31st January 2022, 03:51 PM
homer simpson's Avatar
Try this
Old 31st January 2022, 05:20 PM
I love how 'remove engine' is just a single entry in the process (to be clear, am aware how ElsaWin links to other tasks through links)
I wonder if specialists have worked out that it can be done in situ? Mind you, there's probably a fair list of jobs worth doing when the engine is out in terms of rubber bits, seals etc
Old 31st January 2022, 07:21 PM
kele kele is offline
Mine was engine out. Luckily, still under used approved main dealer warrantee back then...
2012 A6 3.0 TDI Avant, Silver, 7 Spd STronic, Bose, ACC, Advanced Parking Camera, Power close / open tailgate, Side and Lane Assist, AMI & Jukebox, Adaptive lights with corner and high beam assist, Through load with ski bag, Audi pre sense plus, sports diff and sport suspension, Panoramic roof, Storage pack, MMI touchpad and VIM, etc. Oh and now retro fit rear seat entertainment
2019 BMW I3. Heat pump, Winter, professional and comfort packs, Harmon Kardon, autopilot
2022 Mercedes EQC 400
Previously: 2009 S8, Silver, B&O, Ceramic Brakes, Advanced Parking Camera, VCDS
2008 A8 3.0 Tdi sport, B&O
Old 31st January 2022, 07:32 PM
I don't see a problem here
Old 31st January 2022, 08:05 PM
Ron is facing the exact same issue with the D3 S8 that was formerly mine. I have seen somewhere that small hands might be able to swap it out, but like Adrian said, its probably best to remove it and use that as an opportunity to address any other stuff.
Old 3rd February 2022, 08:23 AM
roberto's Avatar
apparently its not an engine out job for the skilled engineer
its located n/s rear low down behind the exhaust manifold
so its possible to lower the subframe with the engine/box still on
very carefully of cource
maybe the exhaust manifold off too
Old 3rd February 2022, 09:12 AM
The manifold may come off with the engine dropped slightly, don't think it can come off as it is. There probably is a work around, just like the PS pipe that Delboy did a write up for. I would change that pipe too if it hasn't been done as it's another failure point
Old 3rd February 2022, 09:59 AM
removing engine/transmission for a qualified person with a proper lift and engine cradle isn't that dramatic a task - it's when you're trying to do it on axle stands/ramps using an engine crane in a private garage that options to get to it without removing the engine become of more interest.
Given it's a once in 10 years job I'd say it's much better to have the whole lump out the way so you can assess other jobs at the same time.
Having had a D3 S8 breakdown right outside my house after the power steering hose failed, it pretty much makes it undriveable as the steering is so heavy without assistance. Plus if the pump isn't knackered from the loss of fluid, it certainly will be if you continue driving the pump dry!
Old 3rd February 2022, 10:03 AM
sarg sarg is offline
Do you have a new motor you're keeping quiet?
2002 Mark's D2 S8 FE
2000 FL D2 4.2 QS - SOLD 2011
