Hans, you have requested 1 million Deutschmarks for pressure die cast tooling for production of a <squints at paperwork> an inlet manifold?! Explain yourself!
Well sir, we noticed the inlet manifold on the 32V V8 is a simple sand casting, which is easy to make, and never fails. We suspect they will still be working decades after the warranty expires. <general muttering of discontent> So, we have devised a new inlet manifold of such awesome cunning that we can claim it is progress, but at the same time introducing many new failure modes such as unexplained air leaks, flaps seizing up, and paint peeling off which will start just after the warranty runs out, thus causing the owners many wasted hours of fault finding and unnecessary maintenance. <applause breaks out> Well done Hans, its not quite as fiendish as Simon's cam chain tensioners, but funding approved! ![]() |
![]() ![]() Did he win over the handbrake adjusting mechanism designer?
I can do that on the lift without taking anything apart so he doesn't even get an honourable mention
i guess he didnt get sufficient funding so just decided to make it as difficult as possible for people without access to lifts
![]() Nice work on the manifold though. I removed mine a few years ago and spray painted it but wish i had done a more thorough job as the paint blemishes show badly. ![]()
Autos Autos everywhere... (1) 2015 Tesla Model S: (was 85D, now 90D ![]() ![]() (2) 2002 D2 S8 Final Edition: Bulletproof and faultless: Brilliant Black with Extended (Red!) Leather. Three-times winner of Best D2 1st prize (3) 1997 Fiat Coupe 20v Turbo: Scots (! ![]() (4) 2010 Fiat Panda 100HP. White Pandamonium (Final Edition!!). Pure old-fashioned 6-speed go-karting. |
Gearbox this evening. I've taken as much red ATF out of the torque converter as possible (2.2L) so put it back in the gearbox so I can refill it.
Primed the pump then primed the filter Then I had a great idea! Since I have all the breather ports bunged up, I could put 8 litres of oil in it while it's upside down, put the sump back on, and flip it over. That will save ages compared to pumping it in through the oil cooler ports ![]() I put a cable tie and a support round the bung just in case There we go - 8 litres of oil, plus one in the converter. That should be enough so that on first start it is slightly over filled and I can pop the fill plug out and let it drain to level. Freshly powdercoated sump Magnets back in the correct places Installed Its not leaking so it can sit upside down overnight while the solvent flashes off in the sump sealant, and I will flip it back over tomorrow. |
Put the engine and gearbox back on the separating table
Since I had the engine crane out, I contrived a solution to split the inlet manifold. The strap goes through each inlet port and supports the inner portion. The outer portion is wedged underneath the two box sections which are clamped to the legs of the engine crane A little persuasion from the crane and the inner just popped out ![]() Lift it out and thats it from the top. These flaps open up at high rpm and shorten the inlet tracts. Its an interesting arrangement - the springs on the front hold them open, and the vacuum pods pull them shut at low speed. Presumably this is because the engine has less vacuum at high rpm since the throttle is open, so its easier to let go of the pods to actuate the manifold than it would be to try and actuate the pods. This piece is a very intricate pressure die-cast. The tool for this must have been exceedingly difficult to make with such fine details. The upper manifold is also die cast, but a magnesium alloy, the same as the cam covers. What's particularly interesting is that it looks like the mould must have been sand blasted after machining to give the outer surface a sand-cast alloy look. That's purely for visual effect, rather than an artefact of the manufacturing process. The two halves are sealed together with silicone Back on the engine. Gearbox and torque converter bolted on, starter back on New manifold bolts and powder-coated upper coolant pipe Reconditioned alternator |
Manifold porn
A journey of a thousand+ (epic) miles, begins with a single step, (to the door of an 8). Lau Tzu |
Is the manifold a repair project or just take it apart and admire Han's design excellence...??
Paul Gosport UK ________________________ Polestar 2 Long Range Audi S8 2002 https://forum.a8parts.co.uk//showthread.php?t=16187 Honda Jazz Harley Low Rider 107 Stage 2 Harley Sportster 1200 |
Take it to bits and see how it works
