Old 20th February 2022, 09:21 PM
Well, the factory used an oil cooler everything from the 180hp 2.5TDI and up. Its hard to say whether it would be up to the job without the cooler unless you measure it once it's built. Worst case, you would have to swap to an A6 version with the cooler, but its probably worth a try without.
Old 20th February 2022, 09:34 PM
Fredde Fredde is offline
Thanks for the info unfortunatley i have the wrong diff so Will be needing that too and i looked up cost for bringing that junk car home and its pretty much the same cost as the car so Will be holding off on buying the car and hope to find one with the propper gearbox and diff that i need Will probably go for a a6 2.5 tdi as you mentioned. Atm planing to do the swap summer 2023 so plenty of time to find the ideal parts
D2 A8L 4.2 AQF 4.2 LZ9W Ebony Black Pearl Fully electric rear seats D3 s8 front brakes s8 mirror housings 18x8 Avus 3 winter wheels PDC rear blinds Nav Electric steering wheel adjustment TPMS Leather pack 1 with retrofitted stitched leather lower dash panels folding auto dimming mirrors solar sunroof cold weather package CD changer double glazing all around memory seats passenger seat adjustment from rear seat Bose servotronic xenon plus headlights
C5 Allroad 4.2 BAS 4.2 LZ6G Irish Green Metallic Bose RNS-E Rear Blinds folding auto dimming mirrors Heated MFSW with shift buttons PDC Recaros heated seats all around CD changer Nav
B5 A4 STCC Edition AJL 1.8T Quattro Built engine GT28RS maxxecu Remote locking Trip computer Sport seats Eibach/Bilstein suspension Flexfuel
C5 A6 1.8T Quattro AWT 1.8T Reliable, unlike the others
Previous Audis B7 S4 Avant B5 A4 Avant 1.8T B8 A5 SB 3.0tdi C5 A6 1.8T C5 Allroad 2.5 TDI
Old 20th February 2022, 09:37 PM
Would a gearbox and diff from another c5 work? Or is there some reason to only use the tdi stuff? Otherwise i can look att 2.7 2.8 3.0 Cars Adele.
Old 21st February 2022, 06:17 AM
The 2.7TT C5 is actually one of the closest gearboxes to the factory S8 manual, along with the B5 S4, so if you can find one of those that's perfect. You'd get a nice spread of ratios with a slightly higher cruising rpm than you have now. The C5 diff works in the D2 as well.
2.8 afaik was only 5 speed. The 3.0 does appear to have come with the 01E, but I've never seen one so may be a Euro market thing again. No idea what the ratios on that would be like.
The reason to use the TDI stuff is that its slightly stronger and used to be very cheap. The high 6th looked like a good thing until I drove it and realised it wasn't.
Old 21st February 2022, 07:41 AM
Ow that’s nice those are not to uncommon I actually found a c5 s6 box that should work right? Also found a cheap ish rs6 auto diff and that is listed as 37:9 which i think is a 4.111 diff right? I know the guy with rs6 engine in his s8 here in Sweden is using tdi box with rs6 diff
Old 21st February 2022, 08:14 AM
C5 S6 manual? Thats an incredibly rare thing of myth and legend! The ratios on that are nigh identical to the S8 manual so that would work. The only thing special about the RS6 diff is the heatsink on the bottom which isn't needed for normal applications, but if its cheap there's no reason not to use it.
Old 21st February 2022, 08:33 AM
Thank you so much for all the info you’re great I feel like I have a grip on the engines but the gearboxes are a bit of a mystery.
