Old 11th April 2019, 02:24 PM
RICKY D's Avatar
RICKY D RICKY D is offline
Goran that is something else!
I’m at work so will have a read through the thread and link properly later.
Old 12th April 2019, 06:14 AM
27litres's Avatar
27litres 27litres is offline
That's funny,
Swapping old school 350 Chevs into series 1 and series 2 XJ6s used to be pretty common back in the day - cheap horsepower and better reliability than the old 4.2 XK block.
I've driven a few LS1 powered Commodores and Statesmans. Low down torque isn't that strong - about on par with the S8. Modded they're much better, my mates Monaro with headers, exhaust, throttle body and tune was very torquey. T56 was still slow though...
I think LS3's are much better - need to borrow my mate Luke's SS!
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
Old 7th February 2022, 10:38 AM
I520VT I520VT is offline
Having a complete 4.0tfsi with short block damage sitting for a while and now found a engine and gearbox from a burned 2015 RS6. This shortblock looks to be in good working order just dirty so I will have to fully pull it apart and build one good 4.0. Also have the RS6 8hp90 gearbox.
So ofcourse my 1999 D2 I have been using as a daily for the last 10 years seems like the perfect candidate for this engine and gearbox.
Problem is I don’t want it manual gearbox so that will add all kinds of complications. First I will focus on getting the engine and gearbox ready then I will probably buy a old D2 to see what’s needed to get it to fit.
Old 7th February 2022, 07:44 PM
Ronin Ronin is offline
you are a brave man!
Old 11th April 2022, 11:27 AM
At least it all first between the suspension towers and inside the trans tunnel. Subframe will need lots of modifications to make it fit and some suspension stuff probably also to make enough clearance for the driveshafts. Stock turbos probably aren’t gonna fit because they’re placed really far backwards and they almost hit the firewall even without the downpipes. So big single seems like the way to go now.
ID:	28133   Click image for larger version
ID:	28134   Click image for larger version
ID:	28135   Click image for larger version
Old 10th May 2022, 07:41 PM
Audifan Audifan is offline
This is exactly what I want to see.
Old 10th May 2022, 08:22 PM
S81 S81 is offline
In guessing you'll have to install it just were it physically fits rather than being able to give any consideration to the weight distribution,
will the rs6 set up be pushing 500 + bhp ,(i really like what your doing )
Daily driver
Previously owned
Audi 80 1986 1.8 white
Audi 80 1990 2.0 red
Audi A4 1996 1.9 tdi green
Audi A6 1.9 tdi 2000 blue
Audi tt 225 2000 silver
Audi s8 d2 2002 fe grey
Audi a8 4.0 tdi d3 2006 black
Audi a8 3.0 tdi d3 2010 black
Old 6th June 2022, 03:45 PM
The weight distribution will be better then original, the engine will be like 20cm more backwards.
Doesn’t look like I made much progress but after lots of measuring and thinking I choose to use D4 4.2tdi engine mounds because they’re not as weird as the C7 ones and started to make the subframe. Made the front mounting points and started to see how the subframe will be with some plastic tubing. Now I’ll order the tubing and stuff to make the rear subframe mounts.
I choose not to use subframe rubbers because it will make the car a lot stiffer and the D4 also doesn’t have subframe rubbers so with using the d4 engine mounts I don’t expect much vibrations.
For power I’m looking for 800-1000hp. Stock this c7 rs6 engine has 605hp
Old 6th June 2022, 03:48 PM
Forgot pics 😅
ID:	28628   Click image for larger version
ID:	28629   Click image for larger version
ID:	28630   Click image for larger version
ID:	28631   Click image for larger version
ID:	28632   Click image for larger version
ID:	28633   Click image for larger version
ID:	28634   Click image for larger version
ID:	28635   Click image for larger version
Old 7th June 2022, 12:03 PM
sarg sarg is offline
Forgot pics ��
Pretty sure I spot an E9x M3 in the first photo
Or is it an E6x M5?
2025 Hyundai Ioniq 5 N
2020 BMW M340d xDrive
