#111
seeing the slightly conical shape, does it replace the old spring mount on the rear control arm?
#112
Much smaller
#113
Last try:
Some tool to press in the windscreen trim? |
#114
Makes you scream in the morning when you step on it
#115
Is it a 3D-printed solution to fixing my abused scuttle cover back in place?
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
#116
Technically correct
Well done The original is in better condition than the replacement, barring this centre support, so I'm going to repair it rather than replace. This printed part is bonded on underneath in place of the chunk which is missing (using methacrylate structural adhesive), and will function the same as the original |
#117
Excellent stuff! Insider knowledge helps here obviously.
#118
I put all the rear suspension back together and forgot to take any more pictures, but its much the same as the stuff I already showed.
The front headlight level arm was seized, and the rear wasn't far behind so I made a new pair: Turned a couple of bushings for the front C-links on the lathe - the links now sit vertically when the car is on the ground, the same as the A4 links did on the FE. This should make the links last much longer This is the printed repair piece bonded to the scuttle trim Fits perfectly That's all the mechanical stuff finished so off for a wheel alignment in the morning, and then on to the last few bits in the interior |
#119
#120
Ahhh! so thats what it was
