Old 3rd July 2022, 10:23 AM
S81 S81 is offline
When you remove the oil cap on the engine i know my car goes of idle ,the chap i know who does a lot of engine work says its to do with it being a positive pressure engine ,i'm sure someone here will know exactly what that means
Daily driver
Previously owned
Audi 80 1986 1.8 white
Audi 80 1990 2.0 red
Audi A4 1996 1.9 tdi green
Audi A6 1.9 tdi 2000 blue
Audi tt 225 2000 silver
Audi s8 d2 2002 fe grey
Audi a8 4.0 tdi d3 2006 black
Audi a8 3.0 tdi d3 2010 black
Old 3rd July 2022, 10:49 AM
Furryhobnob Furryhobnob is offline
You have PM
Have replied Ian, thanks
Old 3rd July 2022, 12:42 PM
Positive Crankcase Ventilation (PCV). It's a bit of a misnomer tbh because intake vacuum is applied to the crankcase to suck out any combustion gases which escape past the piston rings. That makes the pressure in the crankcase negative at low engine load, so I guess it really means 'we definitely are ventilating the crankcase' The breather pod cuts off the vacuum under heavy load or wide throttle openings, since there is no vacuum to do anything, and high load on the engine seals the rings up more so there is less blow-by to recover.
When you remove the oil cap, you basically allow a load of unmetered air in to the engine via the breather pod, which upsets the combustion because the ecu doesn't know about it and so struggles to compensate.
If you remove the cap and it doesn't affect a bad idle then you have an air leak somewhere. The first place I'd look with this one is the inlet manifold gaskets, since its been off previously. Not sure how complex the vacuum system is on the V10, but thats somewhere else to look.
Also, someone please buy this because the price is verging on me buying it just for the engine and I have enough projects already!
Old 3rd July 2022, 01:16 PM
If homer simpson doesn't have it then someone has already dropped me a pm saying they will take it, I'll just be glad it's going to someone willing to give it some tlc and get it singing again, cheers
Old 5th July 2022, 06:37 PM
Well I've certainly garnered alot of interest, in people wanting to buy and others with advice of what the issue could be, because of this I'm going to withdraw it from sale for the time being and try and source the idling issue myself.
I feel this is the right path to go down right now as there's not many of these around and it would pain me to see it stripped or used as a donor without me first trying, hope everyone interested understands. Regards
Old 5th July 2022, 08:00 PM
Once everyone else has done the heavy lifting for you, you've swivelled
Old 5th July 2022, 08:09 PM
What do you mean Tony? Heavy lifting in what sense?
Old 7th July 2022, 01:59 PM
roberto's Avatar
roberto roberto is offline
2nd dibs please ill take it
pm sent
Old 7th July 2022, 06:06 PM
homer simpson's Avatar
pm sent
I there were a few in the queue ahead who would have purchased this had it not been withdrawn.
I was due to collect this on the weekend but it was withdrawn from sale, which I understand, we are all entitled to change out minds. The car is cheap but can also become a money pit to put right.
Even though I would've loved to purchase this, I think it's fair and great that furryhobnob is going to have a crack at it. Forums are all about helping other members and I'm sure it can be sorted proving the OP has time and budget to sort it. Others may have a different view and they are entitled to it. I'll await the fix thread, let's see if we can help out and solve this one
Old 8th July 2022, 11:24 AM
roberto's Avatar
Default i understand
yes no problems hope he fixes it..
i was going to 3.0tdi it LOL
