Old 14th December 2022, 03:55 PM
Ronin Ronin is offline
R/T button now working, so thats 5 out of 6 buttons on the wheel working.
On with the reasearch to get the last one worky worky
Old 8th May 2023, 04:48 PM
Had a spare moment to experiment with GPS antenna positioning.
I decided to move it out of the boot lid as I will be fitting a gpswart-less boot lid soon.
So i decided to de-lid the antenna and put it in 3d printed box which will be attached with double sided sticky tape:
First fitting location I tried is dash, it would have been mounted under the dash, above the vents:
Second location is rear parcel shelf:
And here's the reception quality in the original location:
I ended up picking rear parcel shelf for it's final resting place.
Old 8th May 2023, 06:30 PM
It's a very long time ago now, and on my PF S8, but I ended up putting the "puck" outside at the very rear of the back window, just in front of the boot lid.
I'll see if I can find a picture...
Much better reception there as the rear screen does block the signals to an extent. And that was for the very rare RNS-C.
It was a bit of a PITA to graft it onto the existing wiring, but as you're running a new one should be pretty simple.
Old 9th May 2023, 09:38 PM
Thumbs up
Was the gps module in the boot lid incompatible?
The reason why i de-lidded mine was to hide it under the parcel shelf trim to have as much of an oem look as possible, this may be a good idea for others thought
Old 10th May 2023, 07:50 AM
Yes, in the sense that it had totally failed and I didn't want to buy a ludicrously expensive replacement from Audi then pay extra to get it sprayed the right colour.
I think it cost about £10. This was before the days of A8parts, or certainly before I knew of them or this forum.
I actually fed the cable from the puck antenna under the boot rim seal then up the cable run into the boot lid and joined into the existing wiring there.
Might seem a bit weird, but it was reasonably accessible and there was a connector linking to the aerial on the boot lid.
Getting the boot lid inside trim off is pretty easy and you can then access everything fairly simply.
So I didn't have to cut any cables or go rummaging in the cabin behind trims and under carpets looking for cable runs.
I think I needed an adapter of some sort as, inevitably, Audi use different coax connectors to the rest of the GPS world.
Old 24th May 2023, 04:08 PM
It ended up going here as there was a perfectly sized cut in sound proofing there from the factory, lol:
This is a TPMS system i installed for another forum member on the weekend too, it even shows spare tyre pressure:
Old 24th May 2023, 06:42 PM
40psi??
Paul
Gosport UK
________________________
Polestar 2 Long Range
Honda Jazz
Harley Low Rider 107 Stage 2
Harley Sportster 1200
