Old 29th December 2022, 09:08 PM
Turns out it was the lower hinge partially seized on the driver's rear door
Removed the hinge with the door closed so that it stayed put
Replacement hinge from Prestige in place and now the door opens and closes nicely
The rear door triangles are utterly ruined. I can't just leave this while the door is apart
Luckily I have a pair which have been powdercoated, flatted, and polished
I always mark the bolts when taking a window frame out so that I can at least start by putting it back in the same place it came out. Almost always this doesn't work and the frame still has to be moved about to close properly. I was quite surprised when this door went back exactly as it came apart
Back together just waiting on the door card
ID:	29156   Click image for larger version
ID:	29157   Click image for larger version
ID:	29158   Click image for larger version
ID:	29159   Click image for larger version
ID:	29160   Click image for larger version
ID:	29161   Click image for larger version
