Old 12th March 2023, 03:04 PM
nakata nakata is offline
Default Audi D2 FL instrument cluster
Here is one project with final design for instrument cluster for D2. Is used C5 cluster fitted to D2.
Now A8 D3 4.2 40v Supercharged!!!
EX: A/S8 D2 4.2, moded done: Manual gearbox, Recaro seats, RNS-E + OEM Bluetooth with working MFSW, S8 converted engine, S8 susspension, Solar roof, RS6 brake setup and bigger servo and pump
Future mod: RS 4.2tt engine.
Old 12th March 2023, 03:22 PM
Nice! Thats C5 cluster internals in a D2 cluster housing?
Do all the buttons still work? Does the fuel gauge behave properly?
Old 12th March 2023, 03:39 PM
Ronin Ronin is offline
What are the main benefits of doing this?
I can see that you lose the colour display, but gain the voltage gauge
Old 12th March 2023, 04:13 PM
and oil temp gauge. So annoying that the D2 measures oil temp but won't show you it.
Old 12th March 2023, 04:20 PM
Fuel gauge is need to be reprogaming eeprom to work properly. On C5 work on backwark. And with different resistent from sensor.
Old 12th March 2023, 04:22 PM
А6 internals with new custom face to D2 housing.
Main benefits is ABS 5.7 and D2 have modern brakes. But this is other modification.
Old 12th March 2023, 04:41 PM
I wonder if that would allow 'proper' RNS-E directions on the DIS? I expect it should, given the RNS-E was available in very late C5s
Old 12th March 2023, 04:42 PM
This car not have RNS-E, so cant confirm.
Old 13th March 2023, 07:07 AM
pete-p's Avatar
pete-p pete-p is offline
Same with the battery gauge. Why do manufacturers remove the useful dials all the time.
Cars...
Old 13th March 2023, 11:34 AM
Main reason is not for extra gauges, but very good upgrade for ABS and brakes. D2 not have good brake at all, which is caused by bad ABS system.
