Interesting. I don't think I found this but it does sound feasible. Not sure if I changed the hazard switch or not tbh but its worth a try.
Thanks for all your input Steamship and MJ. Looks like a job for the weekend owing to lack of time and dicey weather. I think it is within my limited capability.
MJ can I substitute WD40 for contact cleaner? Is it prudent to get hold of a new hazard flash unit if such an item is available? Quote:
Paul Gosport UK ________________________ Polestar 2 Long Range Audi S8 2002 https://forum.a8parts.co.uk//showthread.php?t=16187 Honda Jazz Harley Low Rider 107 Stage 2 Harley Sportster 1200 Last edited by strummagnet; 28th March 2023 at 03:31 PM. |
All those engine components are run from the same fuse - S117 'control element fuse' which is a yellow 20A in the ECU box. I'd suggest replacing the fuse and giving the fuse holder terminals a spray with contact cleaner / WD40. Its likely there is some corrosion or grot on the terminals from when it was damp in there.
I have a box of hazard switches if you want one posting, or are passing to pick one up ![]() |
I noticed some condensation to the underside of the ECU box lid. You would think there must be some way of ventilating this box to alleviate this? Crash implausible error has disappeared. ![]() All intermittent have gone. ![]() On to the Airbag issue.
Paul Gosport UK ________________________ Polestar 2 Long Range Audi S8 2002 https://forum.a8parts.co.uk//showthread.php?t=16187 Honda Jazz Harley Low Rider 107 Stage 2 Harley Sportster 1200 Last edited by strummagnet; 7th April 2023 at 04:39 PM. |
