Old 3rd January 2023, 10:47 AM
From the windscreen vent being slightly recessed it appears to be the regular dash with leather over the top. I was sort of expecting the original dash moulding without the vinyl to make up for the extra thickness, but that doesn't seem to be the case with it in the car. I'll find out more when it comes out.
I would concur. I was slightly disappointed that it does indeed seem to be a standard dash with the leather plastered straight on top, but as Sarg has just suggested, it does pave the way to potentially doing it aftermarket and it should look no different.
The D3 is the same, with the leather on top, so some of the plastic fittings aren't quite as flush as they should be.
Old 3rd January 2023, 12:37 PM
ThisWayUp ThisWayUp is offline
Yes - Seems to me that one of the many good TVR trimmers could be a starting point for this, given the nature of thier typical work on later Griffs', Chimeras and Cerberas.
I recall seeing the original 6 Series BMW with the extended leather option, and it looked nice, if a little homemade..
2000 Audi S8 D2 4.2 V8 FL
1997 TVR Cerbera 4.2 V8
1992 Peugeot 205 Gti 1.9
Old 13th January 2023, 08:00 PM
Spanker's Avatar
Spanker Spanker is offline
I saw this back in 2019 on Facebook by a company called M-Art. I think they are Croatian.
ID:	29184   Click image for larger version
ID:	29185   Click image for larger version
ID:	29186   Click image for larger version
ID:	29187   Click image for larger version
ID:	29188   Click image for larger version
ID:	29189   Click image for larger version
ID:	29190   Click image for larger version
ID:	29191   Click image for larger version
ID:	29192   Click image for larger version
ID:	29194   Click image for larger version
ID:	29195   Click image for larger version
ID:	29196   Click image for larger version
ID:	29197   Click image for larger version
ID:	29198   Click image for larger version
ID:	29199   Click image for larger version
ID:	29200   Click image for larger version
Dean
Old 13th January 2023, 08:07 PM
Ronin Ronin is offline
A nicely hidden logo above the cluster.
Theres a guy on the polish d2 group that has a suade covered dash with red stiching, it makes it look like a golf GTI but this one is tasteful.
Old 13th January 2023, 08:47 PM
monkeyboyuk monkeyboyuk is offline
I saw this back in 2019 on Facebook by a company called M-Art. I think they are Croatian.[
Oooh that’s rather nice
2021 Q7 4M, 3.0tfsi MHEV Black Edition
1997 D2 PF 4.2q, silver, Sport on roughly 90k and counting…. ** FOR SALE **
1990 2.3 20v 7a Coupe Quattro
**SOLD** 2014 D4, FL 3.0tdi, phantom black, sport exec lwb
Old 29th March 2023, 08:44 PM
A bit more progress on this, including liberating the dash.
Genuine heated screen, which these days is worth more than the rest of the car!
Botang's hole which caused much of the sadness in the cabin. Since the dash is out its trivial to pull the electronics box and fix this now for the next owner
Along with loads of general crud in the raintray
and in the electronics box, which someone had attacked with silicone, trying to fix the leak in completely the wrong place
Tape removed
3D printed grommet fitted, which ought to seal the hole on its own
Coated in seam sealer to be sure
The previous perpetrator had snapped the stud holding the front of the electronics box so I might as well fix it while its out
Grind off the stump and drill a hole
Rivnut
The fuses are badly corroded from moisture so these were replaced
Verdigris on the fuse holder terminals. All these were thoroughly cleaned with contact cleaner, as were all the electronics box connectors
Ship shape again
The rear bracket for the header tank is broken off. I've never seen this before but I assume it is from some gorilla leaning on the rusted screw trying to get it out. This is a future-owner problem.
ID:	29422   Click image for larger version
ID:	29423   Click image for larger version
ID:	29424   Click image for larger version
ID:	29425   Click image for larger version
ID:	29426   Click image for larger version
ID:	29427   Click image for larger version
ID:	29428   Click image for larger version
ID:	29429   Click image for larger version
ID:	29430   Click image for larger version
ID:	29432   Click image for larger version
ID:	29433   Click image for larger version
ID:	29434   Click image for larger version
ID:	29435   Click image for larger version
ID:	29436   Click image for larger version
ID:	29437   Click image for larger version
Old 29th March 2023, 09:01 PM
Excellent, good to see that you're now well enough to start tackling your own stuff in the workshop, but be careful not to overdo it!
Obviously there's additional motivation here of "removing the object you bought from its packaging" Like Christmas but nearer Easter.
Old 29th March 2023, 09:17 PM
Audifan Audifan is offline
Are these 3D printed grommet available to purchase? I would like to purchase one please.
Old 29th March 2023, 09:18 PM
GarethS8 GarethS8 is offline
Glad your better and well enough to crack on with your own witw ,��
Plus Way to Many others
Old 30th March 2023, 06:45 AM
Spanker's Avatar
Yay!! More WITW!!
I've not seen the word "verdigris" used in a very long time.
Thank you for reacquainting me with it
I guess you didn't fancy the hassle of transplanting that windscreen whilst you're in there.
It would have looked good in Red Dwarf
Dean
