Old 19th May 2023, 02:49 PM
Well this became odd. Sort of.
Took the car in to be checked out and it was found there was very little gas to recover from the system. Lines were checked for leaks and none present.
Refilled and has been ice cold for the last 24hrs with all controls working.
Sorry if I mis-directed you chaps.
Paul
Gosport UK
________________________
Polestar 2 Long Range
Honda Jazz
Harley Low Rider 107 Stage 2
Harley Sportster 1200
Old 19th May 2023, 03:32 PM
Sounds like a good outcome - especially given the weather/forecast
Old 19th May 2023, 04:19 PM
Vexing because it had numerous new parts and seals. It might need some dye injecting and then going over with a blacklight to see if the leak is visible.
Old 19th May 2023, 04:35 PM
Saff Saff is offline
Sounds a bit like my D4, tested ok for leaks but only about 70g of gas recovered. Refilled to I think 780g.
Glad you're all sorted.
2010 D4 SE Executive 4.2 TDI
Old 20th May 2023, 08:54 AM
Yes it threw me as you put new condenser, dryer and compressor on. The fact it switched from ECON to normal (though no difference); I thought the worst.
Hopefully that's sorted it. The 'Aircon' chap said there were no 'discernible' leaks but it wasn't fully tested.
Paul
Gosport UK
Honda Jazz
