Old 30th June 2023, 08:04 PM
Default WITW - A8 Lang
Some of you may remember I bought Johnny Quattro's A8 Long back in December last year, to save it from imminent demise. It's been lurking on the driveway since then while I had long covid (ironic), with me intending to fix it up and flip it.
Cue a conversation with a friend who happened to comment that "I really want a V8 again, but E39s are so expensive". Well... I can help with that I've been working on it for a couple of weeks now, still pretty limited on throughput but I'm getting stuff done.
In some circumstances the L looks so well proportioned you don't notice the extra 127mm.
The grey interior is dead. The extended leather door cards have suffered the same fate as the murple's and rotted away in our somewhat moist climate, so the swing lower trim is all getting swapped for black. The platinum alcantara headlining is staying of course, and the dash is already black which saves me some work.
First order of business is swap the door cards and realign all the door skins and window frames as they are typically all over the place.
One is never too old to learn new things. This trick with the door card I learned from Marcel and it left me wondering why I'd been struggling with them for so many years
The rear left window frame had been replaced so needed some extra alignment as they always do when swapped between cars.
The door lining / bitumen sheet thing appears to have undergone gravitational collapse. Good luck finding a used LWB door lining
So I made one from two standard linings
Nice black door card
Driver's door next, including replacing the mirror as the folding mechanism had got out of sync.
and rear right
Don't need these any more
Interior removed
Never seen a mouse nest in the centre console before. No idea how the little buggers sneaked in there Its an ongoing battle to keep them out when things are parked on my very rural driveway.
Don't need that any more either
Stripped bare
This car has been on my driveway with a dehumidifier running pretty much constantly for 5 months. Its still wet under the carpets.
I got the replacement carpet professionally cleaned by my friend Owain at MAD About Detailing
Much nicer
LWBs have a switch in the rear passenger door to move the front passenger seat back and forth. However, as this car has been retrofitted with the sport Recaros this switch was non-functional as they don't have the extra wiring. This will not do
The round black connector is for the rear door switch
The switch wiring is most cunning and is wired in series between the longitudinal adjustment switch on the seat and the motor. Its simple to break in to that circuit in the connector between the seat harness and the motor
so I made an intercept harness which connects the rear door, but is entirely plug and play This is the testing stage. I forgot to take a pic with the connectors attached.
Now the rear door switch functions as it should with a recaro in the front
ID:	29767   Click image for larger version
ID:	29768   Click image for larger version
ID:	29769   Click image for larger version
ID:	29770   Click image for larger version
ID:	29771   Click image for larger version
ID:	29772   Click image for larger version
ID:	29773   Click image for larger version
ID:	29774   Click image for larger version
ID:	29776   Click image for larger version
ID:	29778   Click image for larger version
ID:	29779   Click image for larger version
ID:	29780   Click image for larger version
ID:	29781   Click image for larger version
ID:	29782   Click image for larger version
ID:	29783   Click image for larger version
ID:	29784   Click image for larger version
ID:	29785   Click image for larger version
ID:	29786   Click image for larger version
ID:	29788   Click image for larger version
Old 30th June 2023, 09:01 PM
gninnam gninnam is offline
Most excellent work as usual
Andy.
Current cars:
BMW i4 M-Sport
Peugeot 207 (the sons)
Gone but not forgotten
Old 1st July 2023, 05:54 AM
Spanker's Avatar
Spanker Spanker is offline
I didn't realise how much I missed the WITW series until I saw this today.
And a platinum/black combo too. Cool.
Next episode please
Dean
Old 1st July 2023, 07:10 AM
Give the Doctor a chance, she's not 100% yet.
Good stuff Michaela. Take it easily.
Old 1st July 2023, 07:34 AM
Spanker's Avatar
Of course. No rush. I didn't want to seem impatient.
Just giddy with excitement 😁
Dean
Old 1st July 2023, 08:53 AM
johnny_quattro's Avatar
I feel honoured to see my ex-girlfriend of 11 years being tended to by the good doctor. I had to say goodbye to the A8L thanks to our friend Sadiq Khan. My current S5 (B8) is Euro5-compliant.
The silver QE2 looks much nicer with different door cards. The electric door mirrors moving forwards and then clicking past the correct position and then ending up at '10 to 2' started happening the day I got the car back from the paint shop, back in 2015. I couldn't work out what had happened, so I had a look at them and quickly discovered that I didn't know what I was doing, so I left it well alone.
This car has the badge of honour of having done 3 laps of the Ring back in 2018, and also parked up next to Sabine's Porsche by mistake back at the Longhorn Saloon where I stayed.
You did make me laugh MJ when I read your comment about the special limo button: "This will not do". It was also a genius move making up that replacement LWB door lining.
I will be following this thread with great interest.
Old 1st July 2023, 04:44 PM
Next episode please
100% agree. But no rush, just nice to see this/you back up and running, but at an appropriate pace....
Old 1st July 2023, 06:37 PM
Still as nimble as a SWB?
Paul
Gosport UK
________________________
Polestar 2 Long Range
Honda Jazz
Harley Low Rider 107 Stage 2
Harley Sportster 1200
Old 1st July 2023, 07:57 PM
A silly question about the passenger seat movement control from the rear seat.
Does it have an interaction with the (airbag-related) seat occupancy sensor, or does it just rely on anyone sitting up front shouting "Oi"?
(I think I know the answer to that... )
Old 1st July 2023, 08:12 PM
Yeah I think you know the answer to that
An inauspicious day today. I was tracking down why VCDS won't talk to anything and discovered a fishpond in the electronics box. Did the usual and blasted all the water out, contact cleaner, and WD40, then refitted all the connectors. Now it won't start
The ECU has corrosion on several pins and although its rare for them to get damp inside, it appears to have a short on the K-line so stops everything else talking. Of course that also means it won't tell me why it won't start... sigh
