Old 26th September 2023, 01:28 PM
The problem persists! Sometimes it will stay clear for 600 miles or more, but the engine light eventually comes back on. IIRC, Mike suggested that the vacuum valves themselves might be blocked and that they can be flushed out with Fairy Liquid and water.
Can this be done in situ, because it looks like a right sod to remove them?
Old 3rd October 2023, 08:20 AM
if you're getting a code for both banks, and all the vacuum pipework is good, its unlikely to be the valves. More likely the pump, which is in the airbox. That can seize up from moisture ingress but won't trigger a specific code. There might be an output test for it in VCDS so you could try that and see if you can hear the pump running.
Old 5th October 2023, 08:57 AM
I replaced the plastic pipes at the back of the engine with braided rubber and the warning light and error code (for both banks) disappeared immediately. But then a while later it was back. All the pipes that I can see look fine, but some of them seem to disappear into the depths of the under-bonnet wilderness!
I’ll have a look for an output test on VCDS. Thanks again.
