Old 2nd October 2023, 10:30 AM
Mossyboy1978 Mossyboy1978 is offline
Not in my ownership - and I've had it about 7 years.
The mystery continues....as does the beeping....
2002 S8 Aqua Pearl, entirely original apart from FE 20" OEM wheels and Milltek exhaust.
Old 2nd October 2023, 02:55 PM
Ronin Ronin is offline
You need to reseat the connectors at the back of the cluster, I've had the same a week ago.
Old 2nd October 2023, 03:22 PM
Thanks Ronin - that sorted that issue!
Coolant level warning remains.....
Old 3rd October 2023, 01:50 PM
Is it possible that this is something to do with the coolant temp sensor at the back of the engine?
Rather than the one at the bottom of the expansion tank?
Old 3rd October 2023, 02:43 PM
Can you scan the engine with vcds and tell us the codes?
Old 3rd October 2023, 05:41 PM
Sadly I don't have one.
Anyone in Hertfordshire on here with a VCDS?
Thanks
Old 3rd October 2023, 08:43 PM
Just over the border in South Bucks.....
Old 3rd October 2023, 09:38 PM
The most basic vcds lite cable is like £13 on eBay
Old 4th October 2023, 09:24 AM
Could well be, I've certainly had problems with them and replaced more than one.
Important to remember that the sensor has two separate parts to it, one feeds the dash display, the other the ECUs. So it can (and will) show a normal temperature as well as cause problems.
Tip: If you do replace it buy the o-ring seal and retaining clip as well!
Old 4th October 2023, 06:59 PM
No. If that had failed to max temp the fan would be howling and the temp gauge pegged at max. It'll warn at 130c and you'll know about it.
You may actually have a cluster failure. Its rare but not unheard of.
Next step if it were in the workshop would be to pull the cluster and locate T32b/18 and ground it right at the cluster. Dismantle the connector & find a spare pin and a bit of thin wire and just remove pin 18 and replace it with the spare. Ground the bit of wire and see what it does.
If the warning goes away you have a wiring issue between the cluster and the tank. If the warning doesn't go away you likely have a dry joint in the cluster itself which would require professional assistance to solve.
