Old 20th November 2010, 06:38 PM
A8 Doc A8 Doc is offline
Default Fitting AMI Interface
You will require an AMI interface out of an A4/A6/A8 - Check part number first, most start with 4E0 which is perfect.
You will need:
4D0 051 530 - Release Tools to remove CD Changer (Approx £5)
4F0 051 510 K - iPod Cable to fit AMI (Approx £20)
4F0 051 592 A - Wiring Harness for Power and Retrofit Kit - (Approx £30)
You will not need the last one if you simply replace the CD changer. I wanted both So that is the official audi dealer retrofit kit number. Release tools make it easy.
Basically drop glovebox, remove the CD Changer first, then fit the wiring harness to split the MOST bus and power for the AMI most, and fit both.
You will require the latest MMI software installed. Let me know if you need a copy. If the AMI is new it will require coding, if not it should work immediately
Done
Old 19th January 2011, 03:28 PM
A8L Chick's Avatar
A8L Chick A8L Chick is offline
This sounds all too easy
Can anyone explain what the hell MOST stands for
And, I am retrofitting this into the black D3 tomorrow hopefully, please can someone show me how the "MOST" connection should be to enable both CD & AMI to work instead of loosing the CD changer.
Unless this is simply plug and play of course? I get the impression I need to connect wires to wires though???
Just a bit of info on the AMI units for the A8... there are only 12 left in stock at Audi HQ, when they are sold they are not making anymore... so if anyone wants to retrofit this into their car they need to do it now
07 Silver D3 A/S8L Quattro S8 front end, Xenons, Bose, Bluetooth, Voice Control, Autodim mirrors, Heated folding mirrors, Double Glazed Windows, Electric Rear & Side Blinds, Black leather Comfort Seats with front memory seats & mirrors, Front & rear heated seats, Interior/Exterior light pack, TV.I.M, AMI, Parking sensors Front & Rear, Air suspension (soon to be lowered), Keyless entry & Start/Stop, 4 zone climate control, Power Boot Open/Close.
Old 19th January 2011, 03:56 PM
Just use a granny knot.
Old 19th January 2011, 05:25 PM
A8L Chick's Avatar
Oi cheeky
I have no problem with connecting wires etc but I would need to know which ones
Old 19th January 2011, 05:36 PM
MOST stands for something like Media Oriented System Transport. It's a fibre-loop that goes round the car components.
Thankfully, you don't have to splice any fibres, but you do need to take at least one of the connectors apart behind the CD changer. Seriously, if you are happy to just put all your CDs on the AMI as MP3 on a hard drive, or iPod then it's a bazillion times easier to fit.
The loom should come with all the instructions on which connectors to take apart and stuff.
Old 19th January 2011, 06:03 PM
A8L Chick's Avatar
Aah I see, thanks hun-thats easy peezy then hopefully.
I will let you know how I get on.
Would anyone be able to give me a step by step for the VCDS? I need to open a module or something dont I??? (this is the bit I have no idea on)
Old 19th January 2011, 07:30 PM
Mine was plug and play, no vagcom work... Connected the leccy, looped through the fiber and voila, the CD changer and AMI both work fine now...
PsYcHe is right though, if you dont have the pukka 'upgrade kit' which comes with the fiber Y connectors and wiring then its far, far easier to remove the Cd changer and put the AMI in its place..
It does rely on a later version of the MMI though, but you'll have that no doubt in yours I would think....
Old 19th January 2011, 09:08 PM
It needs to be something like 3360 or similar to support AMI.
And yes, you may need to turn on media player 1 or 2 in VCDS. it's the main module long coding if I remember rightly (module 07?).
Old 19th January 2011, 11:02 PM
A8L Chick's Avatar
Brilliant-thanks everyone. I should be fine
I have latest software so all fine there
Fingers crossed for tomorrow.
Old 20th January 2011, 10:17 AM
Yep dead easy as agreed. Unplug one plug in other. I have a spare power splitter if you need one.
Get stuck gimme a bell. If you remove the CD Changer keep it.
