Old 18th May 2024, 07:56 AM
Steering angle sensor fault will give those lights on. Failing battery can give all sorts of weird things and usually multiple weird things. If the steering angle sensor is the only fault, it's probably sensor related fault not the battery. I say related because it does not mean the sensor itself is faulty, it could be wiring to the sensor or ABS ECU not seeing data from the sensor.
