Hi everyone
Hope we might have some ideas. Went out to the car after work this evening, 3.0tdi 2008 a8, and when I started it up the abs light and esp light came one, the brake light went red and started flashing, and in the info dash brakes came up with a big red warning. I popped around the corner and the local garage scanned it and it came up steering wheel angle sensor was fault. Would that cause all those lights to come up? I drove home and the car felt OK bar the flashing lights! Could a faulty battery cause this because to me it sounds a bit tired when starting some times. Thanks in advance. Last edited by jt racing; 17th May 2024 at 07:19 PM. |
no experience of D3s, but for sure a dying battery will throw up all sorts of errors
Steering angle sensor fault will give those lights on. Failing battery can give all sorts of weird things and usually multiple weird things. If the steering angle sensor is the only fault, it's probably sensor related fault not the battery. I say related because it does not mean the sensor itself is faulty, it could be wiring to the sensor or ABS ECU not seeing data from the sensor.
The steering angle sensor can fail. It happened on my D3. Fairly simple fix.
OK that's brilliant. Thank you will get one ordered up on Monday and go from there.
When mine failed I had this fault... Code:
Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 A HW: 4E0 614 517 A Component: ESP 5.7 allrad H29 0420 Coding: 0008597 Shop #: WSC 02313 000 00000 VCID: 2149FC83F8DBE6816E-8074 3 Faults Found: 02083 - Message for Delay Request 008 - Implausible Signal - Intermittent 00778 - Steering Angle Sensor (G85) 014 - Defective 01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30 000 - -
Matt 2004 A8 3.7q, 1998 A4 2.8q, 1994 Coupe 2.8q SORN, Last edited by mattylondon; 19th May 2024 at 06:42 AM. |
OK will do that... haven't access to vcds but the garage does seem to have the most up to date system for scanning.
A used one, are the very dear new? |
