I have come across a pair of RS6 front discs.
Are caliper adaptors readily available and if so where from? Thanks Mick |
They're not readily available, but I think they're the same fitment as the FL/D3 setups, so Ben/Oli may be able to help you out with what was needed.
you cant use the rs6-c5 discs with s8-d2 calipers because s8 disc is 30mm and rs4/6 disc is 34mm wide. the fl s8 caliper will take a disc diameter up to 380mm and width up to 32mm though.
the caliper brackets to use the rs4/6 calipers on the fl s8 with the brembo system are here http://cgi.ebay.de/Bremssatteladapte...item1c19199ed2 and also available from urquattro in the post here http://forum.a8parts.co.uk/showthrea...1170#post11170 Last edited by r8dream; 3rd February 2011 at 04:30 PM. |
Bummer. Whats my cheapest caliper option?
