Old 9th February 2011, 03:17 PM
...but other than that, i'm incredibly happy with the car overall...i love it and having owned this one for 2 years now, I'm really pleased with it. The more you add to a car, the more invested you become into it and I've really had a chance to make it my own. I can't think of a nicer car to own to be honest...
I just wish i could drive it more often
Oli
Cant believe its been 2 years...., but then its coming it to 4 years since I first bought it. He does look good Oli, you've treated him well, hes unique, and still subtle, just the way I love em
Old 15th March 2012, 01:39 AM
adjuster adjuster is offline
Nice upgrade!
I have a question.
Are the larger D3 S8 rotors on the same plane as the D2 rotors? (Do they sit out or in more?)
Also how thick are they?
My thought is to use the D3 S8 rotors, since they are quite a bit larger, and either re-locate the D2 S8 caliper out on a bracket to the right diameter postion, but if the rotor is too thick that would not work. (Unless of course you take apart the calipers and add spacers to them, longer cross over tube for the brake fluid to make them wider...)
Just the larger rotors add more braking ability, since you are further out from the center of rotation. (Sort of like adding a cheater bar on a wrench, it multiplies the tourqe, so the same amount of pressure on the pads via the calipers equals more stopping force is what I've been told.)
The larger swept area just allows it to reject heat faster, or store more heat when used, and reject it over more time. (Reducing fade effects.)
So, in theory, just going to larger rotors would add to the braking ability of any vehicle, and the S8 Brembo's are pretty good calipers to start with, they just should have been mounted over larger/thicker rotors.
Old 15th March 2012, 08:21 AM
Assuming you have the correct hubs (you probably do), then you shuold be able to drop a set of D3 brakes on, anything from the standard up to the S8 Ceramics. Though you might also want to keep an eye out for RS6 brakes too as they'll just drop on as well I'm sure.
Old 19th March 2012, 09:19 PM
Good to know, thanks!
Old 23rd April 2012, 12:07 PM
SyncroS8 SyncroS8 is offline
I may have missed this within the post but will your 18s still fit over the larger brakes?
Looking good!
MG
Old 25th April 2012, 11:57 PM
Oli18's Avatar
Oli18 Oli18 is offline
Looking good!
MG
Yes they do! ... With mm to spare
Audi A8/S8 D2 Flickr Group
Old 13th March 2021, 06:04 PM
edinko's Avatar
edinko edinko is offline
Hi guys, i have "found" bolt on solution for A8 D2
aluminium hubs with HP2 front brakes to 360mm discs & dual calliper upgrade from A8 D3 4.2 Tdi or Phaeton MK1 3.0 tdi model. Bolt on solution no spacers, adapters or so.
Today i did not take pictures when i was test fitting on spare hub, because i have literally one pile of 200 different discs and other pile of callipers to find bolt on match, But i will take some photos when install them on my car.
Minimum is 18" wheel, but im not shore wich wheel ET fit.
I knew they fit under my 19" 8.5j ET 45 oem D3 wheels. I will try to measure gap after fitment.
I have put some D3 310mm discs rear and adapters to fit calipers carriers on desired position. Will make thread for them too.
God loves speed.
Earth orbital speed is 107200 km/h.
And someone set speed limit on earth at 50km/h. Well road safety they say. I say that is bad engineering
THREAD WITHOUT PICTURES IS LIKE SKY WITHOUT STARS.
A8 D2 W12 6.0l 2002
A8 D2 2.5 TDI 2000
S8 D2 4.2 V8 1998 Manual transmission
