Old 19th April 2011, 01:10 PM
RanjS8 RanjS8 is offline
Default where to buy this little connector
Would anyone know where I could buy this little sucker......
went to tps today....and supposedly you cant get it on its own....only with a bit of wire as well....
Thanks for your help....
Old 19th April 2011, 01:17 PM
where about is it from Ranj?
Old 19th April 2011, 04:54 PM
Default Little connector
It's one of 4 metal connectors that goes into the grey plug that connects on to the back of the blinds switch....the part number of the grey plug is 993971972.
Old 19th April 2011, 05:07 PM
Don't recognise the connector type. I thought all the sockets that plug onto the switches had tagged spade connectors in. Will root around at the weekend and see if I can find some more info.
Old 19th April 2011, 08:23 PM
jayzee jayzee is offline
Try a local auto-electrician; they should stock most connectors. Trouble with those is they are hard to get hold of, and are supplied in large quantities. We used to use these in my old firm... I'm just trying to think of the manufacturer name... AMP/ Tyco rings a bell for some reason...
Yeah baby!!
Old 19th April 2011, 08:43 PM
darrenjoe90's Avatar
you could buy one from a8-parts
Audi S8 Phantom Black
Old 20th April 2011, 12:24 PM
Default Where to buy this little...
A tagged spade connector will probably do the same job to be honest...I will try it tonite to see if they will fit into the plactic connector....
I decided to order the connector with wire from Tps for now...they actually cost 3.50 each...which is a bit pricey I thought...but not much choice...I will look up those manufacturers cos it would be good to source those connectors for similar jobs...
Thanks for the suggestions guys...
