Old 5th May 2011, 06:44 PM
just give it a short blast and see if that clears the blockage. You may get a bit in the car but it's already damp.
That's what SHE said
Old 5th May 2011, 07:11 PM
Originally Posted by Simon Wallwork View Post
OK, Oh knowledgable one. I'll try that tomorrow if it's stopped raining.
This pipe of which you speak: It has to be 'bent' to fit under the air intake box. I've got that.
Should it also have a 90 degree bend at the very end to fit down the 'ole?
If so, what..about an inch below the bend??
Would that fit in?
Yes, about 1/2" is fine.
Sick MoFo
Old 5th May 2011, 08:00 PM
Fnarr fnarr.
Old 5th May 2011, 08:42 PM
Thats what Psyche's missus said too!
Old 6th May 2011, 05:24 PM
Well, it wasn't raining.
Stripped the interior for de-moistening and cleared the pair of evaporator drains on the tranny tunnel. Mucho water came out. These looked OK but plainly were not. Anyway I was able to blow through them with a bit of hose attached so they ought to be ok now. They were definately blocked before.
Also cleared both engine compartment drains. These were also clogged but I poked wire up from the arch. Their entry points are cunningly hidden.
No luck with the cowl drain though. After ages of farting about, the best result was a fastish drip from both sides of the drain. This later slowed to a slow drip. I shoved every thing (ok, almost everything) that I could wedge in, in and wiggled it about but no real result. The thing will be choked with these damn holly berries.
Any other ideas?
Old 7th May 2011, 01:23 PM
Success!
Copper pipe fixed to garden ose. You need to keep the downward pointing part of your copper pipe short. No more than half inch (as Conan mentioned!) or it wont fit in. (ooh err missus)
Also bend the copper so you can tell when your downpointing end is pointing down. Get it under and wriggle it about.
Sudden whoosh and all the water emptied under the car in about one second!
Brilliant!!
Old 7th May 2011, 07:05 PM
well done Simon perseverence paid off in the end!
Old 7th May 2011, 07:56 PM
Thanks Archi
Yep, always satisfying to fix something properly-- and Free!
Old 7th May 2011, 08:08 PM
Thanks Archi
Free is doubly satisfying!!
