Old 11th July 2011, 09:37 PM
Default vag codes for arming horn auto lock ect ..
http://www.audiworld.com/tech/elec39.shtml
where can i get the uk version so i can code in to honk the horn when i lock the car and also there is an oil level moniter system that can be set to display on the dash when going into the on bord computer ect dose any one have the codes >? also can code the windows to close when you lock the car ect ..
many thanks
Old 11th July 2011, 10:29 PM
here is the vagcom online site Guy - you can download a 92 page manual and clik on the screen shots like its all live
http://www.ross-tech.com/vcds/tour/main_screen.html
Old 12th July 2011, 06:36 AM
When you go into the coding section and hover over the box VCDS throws up a pop up with all the coding you may need.
It basically gives a unique number for each attribute. All you do is add all the numbers for the facilities you want together and enter the result.
Old 12th July 2011, 06:46 AM
Here is a screen shot.
Old 12th July 2011, 09:17 AM
exelent i will have a play with that and see how i get on thanks Guy's
