Old 2nd August 2011, 08:43 AM
engine85 engine85 is offline
Yes it does have the fingerprint system, according to the MMI handbook, i have to enter 'CAR' then 'USER' to enter new users, delete old users as well as the seat/mirror/steering wheel position etc for each individual user, as it is, everything moves to someone else's setup, whic is kind of a pain in the arse.
Old 2nd August 2011, 08:55 AM
In the 'settings' options, is the fingerprint sensor turned off and the key turned on for positions?
Though, where are you? we could maybe have someone nearby do a scan so look for errors, could be the fingerprint system is faulty.
Old 2nd August 2011, 09:01 AM
Thats my problem, to enter 'settings' i need to select 'user'
I presume it must be on, as everytime i unlock the car everything starts motoring around. Unfortunately i live in the middle of nowhere, all the way out in anglesey.
Old 2nd August 2011, 09:05 AM
PsYcHe was reffering to the settings menu, ie CAR > Settings > ....
the fingerprinting has some settings in there. if its set to Key the car picks up its settings in a different manner to the fingerprint profiles
Old 2nd August 2011, 09:17 AM
should you need a scan i get across to Warrington fairly freqently, but there may be someone closer
Old 2nd August 2011, 09:30 AM
I have settings elsewhere, but not related to the fingerprint/memory setup, the car suspension settings should also be under the same menu option, the warning lights come on at start up then extinguish as expected.
If i actually press the fingerprint reader, its says 'not recognized' but nothing happens.
Old 5th September 2011, 06:15 PM
Returned the car after finding a huge list of faults, its now posted on auto trader after someone bought it on e-bay for less than £4500 . .
http://www.autotrader.co.uk/classifi...51ya?logcode=p
It does'nt have sat nav, bose or phone prep, the rear diff requires replacing, the fingerprint reader is not working and locking you out of the suspension menu, the discs/pads all need replacing, the tailpipes are still a differant size and the engine 'hunts' constantly, the abs computer has a fault and various bits of trim are missing/broken . . . but the coil packs are new. Beware
Old 6th September 2011, 07:00 AM
sloss's Avatar
sloss sloss is offline
Not a good motor at all. Glad you got out of it OK
