Old 5th August 2011, 08:02 PM
sloss's Avatar
sloss sloss is offline
Default Wiper headlamp wash delay
I find the headlamps want to wash far too often. It uses huge amounts of fluid every time.
Is there someplace in VagCom where the time can be adjusted?
D3 A8L 3.0TDi
Old 5th August 2011, 08:55 PM
I am not sure but I would say I am afraid not. I do not have washers for headlights in S8 but i did have in A6 and I disabled them 2 weeks after getting the car by pulling the plug for the pump.
Old 7th August 2011, 09:30 AM
sloss's Avatar
Thanks,
I might just do that as I'm fed up filling it up every other day!
Only squirts the windows for about 2 seconds then the headlamp wash uses about 2 litres each side!
Old 7th August 2011, 01:04 PM
could always switch the headlights off when you need to wash the screen (during daylight hours, of course) so they don't fire on the headlights?
Old 7th August 2011, 01:12 PM
I am pretty sure my A6 (1994 C4) lhd back in continent washed them regardless if they were on or off. Not sure if A/S8 is any different.
Old 7th August 2011, 01:18 PM
My D2 S8 only washes headlights if the headlights are on and you pull the switch for more than 1 second constantly. Other option would be to do several short quirts so the headlight wash doesn't cut in?
Old 26th August 2011, 06:34 AM
sloss's Avatar
It's that delay I want to lengthen to about 5 seconds or so.
My Merc only washes headlamps after every 10 times or it might be 8.
I'd have thought this was a VAG Com setting.......aw thing else is
Old 28th August 2011, 07:11 PM
Nollywood's Avatar
Another option is to fit a disable switch, which will cut power to the headlamp washers, when the headlamps are on. You can use an OEM switch, if you have a blank.
