Old 13th August 2011, 03:38 PM
BABOULINET BABOULINET is offline
Hello, thank you for this solution, my AIRBAG light is finally extinguished.
Old 13th August 2011, 03:44 PM
glad to be of assistance, what resistance did you use at the end and is it showing occupied or unoccupied?
Old 13th August 2011, 05:24 PM
I use a 470 ohm 1/4W resistor and the sensor detects the seat occupied.
Old 6th November 2014, 07:12 AM
fireman dan fireman dan is offline
My airbag light is on and Indont want to have to replace the sensor. In the seat
Where do I buy a delete box from or is it a resistor from maplins?
Many thnks.
For the record are the sensors for the seats expensive ?
Regards.
Old 6th November 2014, 08:44 AM
Run VCDS to check the codes first.
If it's an S8 the "usual" problem is the small supplementary sensor in the movable front section of the seat squab.
This can easily be dealt with by just shorting it out; there's a thread about it somewhere with a fair few contributions from me. Very easy to do.
Edit: See main thread: http://forum.a8parts.co.uk/showthread.php?t=114 especially page 4 http://forum.a8parts.co.uk/showthread.php?t=114&page=4
And my own thread: http://forum.a8parts.co.uk/showthread.php?t=4873
Old 6th November 2014, 09:55 AM
Norretal's Avatar
Norretal Norretal is offline
As HP mentions above, the fix he detailed on page 4 does the trick.
It worked for me on my A8, never had a problem again afterwards
Audi TT - 2015 - Ultra
Old 6th November 2014, 11:38 PM
You guys are too kind.
Thankyou. Will take a look now.
