VCDS (aka Vagcom) For all your electronic debug / diag advice queries and mods. |
I find the headlamps want to wash far too often. It uses huge amounts of fluid every time.
Is there someplace in VagCom where the time can be adjusted? D3 A8L 3.0TDi
Men have feelings too. For example we feel hungry..... Last edited by sloss; 5th August 2011 at 08:03 PM. Reason: Added vehicle |
I am not sure but I would say I am afraid not. I do not have washers for headlights in S8 but i did have in A6 and I disabled them 2 weeks after getting the car by pulling the plug for the pump.
Thanks,
I might just do that as I'm fed up filling it up every other day! Only squirts the windows for about 2 seconds then the headlamp wash uses about 2 litres each side! ![]()
Men have feelings too. For example we feel hungry..... |
could always switch the headlights off when you need to wash the screen (during daylight hours, of course) so they don't fire on the headlights?
I am pretty sure my A6 (1994 C4) lhd back in continent washed them regardless if they were on or off. Not sure if A/S8 is any different.
My D2 S8 only washes headlights if the headlights are on and you pull the switch for more than 1 second constantly. Other option would be to do several short quirts so the headlight wash doesn't cut in?
My Merc only washes headlamps after every 10 times or it might be 8. I'd have thought this was a VAG Com setting.......aw thing else is ![]()
Another option is to fit a disable switch, which will cut power to the headlamp washers, when the headlamps are on. You can use an OEM switch, if you have a blank.
2006 Audi A8 D3 Quattro Sport 4.2 TDI - Silver, Family Oil Burner. 2000 Audi A4 Quattro Sport 2.5 TDI - Santorin Blue, S8-Powered DTM Race Car Build In Progress. 2000 Audi A4 Quattro Sport 2.8 30V - Pelican Blue, RS4 Widebody, D3 4.2 01E, High-Spec B5 Build In Progress. |
