Old 7th September 2011, 10:36 AM
No problem. I should get a chance this evening if the weather holds
Old 7th September 2011, 04:49 PM
Here we go. Hope these help. If I've missed something you need to see, let me know
ID:	2296   Click image for larger version
ID:	2297   Click image for larger version
ID:	2298   Click image for larger version
Old 8th September 2011, 06:23 AM
Iyole Iyole is offline
Thanx Mate...... All good...... now I can compare and establish what is aftermarket fittings and wiring.
Really appreciate your assistance....
2002 S8 D2 F/L
Old 8th September 2011, 07:10 AM
Glad to be of help! It's usually me receiving help here.
I have a couple of silicone tubes that recently replaced some worn vacuum pipes, but other than that I think it's standard
BTW - send us some of your weather please...
Old 15th September 2011, 08:52 PM
Had a problem with a drain on the battery....
Isolated to these Resistors + wiring that was very dodgy.....
Busy re-doing wiring and heat-shrinking etc .....
Want to replace the Resistors but have only come up with these leads and don't know where to source them....
http://www.hot-spark.com/HS14BR.htm
Any advice....
Tx
2002 S8 D2 F/L
Old 27th November 2012, 06:54 PM
Exerqtor Exerqtor is offline
You can get the resistor here i'm pretty sure.
http://uk.rs-online.com/web/
Old 27th November 2012, 07:00 PM
Umm, weren't yours red the last time i saw them..... your manifolds, of course!
Old 27th November 2012, 07:41 PM
Having had a decent dry (whats that?) day on Saturday I changed the oil/filter and air filter. (The problems of not having a garage )
I used Mann filters for air and oil filter and in a side by side comparison, the air filter was of exactly the same construction (materials/folds etc) as the audi one i removed with the exception of the Audi logo and numbers. The one I removed looked like the dog had had a go at it before it went in. (the red seal was missing in places.)
The oil filter installed on the car was a Mahle/Knec and of the same construction as the Mann. It was however, crushed when installed so it had a twist in it when i removed it. It looked like it had not seated correctly.
Is this carelessnes by the last servicer or has anyone else seen this?
The last photo is (i think) of the power steering pump. It seems to have a slight leak but there is no apparent loss of fluid levels in teh reservoir. Is it the PS Pump?
Name:	Air filter_Damage.jpg
ID:	5326   Click image for larger version
ID:	5327   Click image for larger version
Name:	New and Old Air filter2.jpg
ID:	5328   Click image for larger version
Name:	New Air filter.jpg
ID:	5329   Click image for larger version
Name:	New Oil filter.jpg
ID:	5330   Click image for larger version
Name:	Powr Steering pp_2.jpg
Old 27th November 2012, 08:54 PM
47p2's Avatar
47p2 47p2 is offline
Might be worth nipping that joint up ever so slightly, there is a copper washer each side of the union that sometimes crushes over time and just need the slightest turn to re-seal them
Nite Blue 3.0L SE Quattro
Old 28th November 2012, 07:08 AM
David, the PS pump was new just before you had the car. You should have a receipt from A4 Audi in the paperwork. So it's still under guarantee.
