Old 12th September 2011, 02:52 PM
If you can get hold of the CDs, then go for an update, but always good to do a VCDS scan first to make sure it's all clear.
Old 13th September 2011, 12:04 PM
Big Blue Big Blue is offline
Got the CDs but the VCDS thing: I've found a download for a lite version but then where does it plug in and how do I use it?
2003 A8 D3 3.7 "Jean-Luc"
1989 190 "Colditz"
2007 Fireblade "The Blade" (Stolen October 2011 )
Old 13th September 2011, 02:38 PM
You need to have the diagnostic cable and stuff too
Hopefully someone localish to you will be along soon that could scan the car for you.
Old 13th September 2011, 03:30 PM
I have a spare Gendan cable that'll work with the free downloaded software, i no longer use as i have a genuine cable now. You'll be quite limited to what can be done with it tho.
Old 13th September 2011, 03:46 PM
Is that a CAN-BUS cable Dezzy? If not, then it's almost useless in a D3
Old 13th September 2011, 03:57 PM
No I'll get my coat
Old 13th September 2011, 05:00 PM
Is VCDS-Lite working with CAN-BUS anyway even if you have CAN interface cable? I though for CAN you needed full software.
Old 13th September 2011, 08:55 PM
Erm... Not sure.. could be right.. and if it's the ross-tech cable, then you can run the full version anyway so it beomes a moot point I suppose.
You may need the full version for the proper diagnostics of MMI
