Old 26th September 2011, 11:33 AM
jamestoo jamestoo is offline
Default Subwoofer Replacement D3 '05 Non Bose
Hi I hope someone can help me please.
My sub. on the rear parcel shelf has blown (i now just get a laud knocking noise) and no bass.
Other than an OME Audi replacement what are the options without too many modifications?
Many thanks
James
Old 29th September 2011, 07:02 AM
FireStorm FireStorm is offline
i would put the standard sub back in.
however i went crazy when i removed mine and put this in.
2.6k RMS in a double bandpass box firing through the ski hatch.
bet none of you have seen the roof of an A8 flexing
Old 30th September 2011, 07:50 AM
Hi Been looking at removal of the sub under the parcel shelf is there a simple way to remove the sub from the parcel shelf without dismantling the seats?
I can't see how it could come out without removing the parcel shelf
any help greatly appreciated
James
Old 30th September 2011, 03:12 PM
Remove the top bose grille
you need to lay in the boot face upwards and take a few clips out the trim (top trim thats below the shelf not the one on the seat) and lever it away from the seat. you can then remove the 4 bolts that hold the sub in.
i cant get mine back in i appear to have lost what it fixes into?, so watch it..........
http://forum.a8parts.co.uk/showthread.php?t=3501
Old 3rd October 2011, 04:02 PM
Hi took the boot roof trim off today and it looks like the bolts you are referring to are only accessible from under the parcel shelf. Mine are bolted into spot welded metal retaining fixings with the bolt heads almost touching the underside of the parcel shelf.
I'm assuming the correct way to remove these is to remove the parcel shelf first? can anyone please confirm?
Many thanks
James
Old 3rd October 2011, 09:58 PM
Many thanks
James
How about just drilling them out from underneath? You can replace with new ones
Old 3rd October 2011, 10:00 PM
Yes good idea i did consider that.
James
Old 6th October 2011, 07:28 PM
i didnt remove the shelf to get it out.
i just had a small person in the boot and i was in the car with the sub grille off holding something IIRC
i gotta figure how it ghoes back in, so when i investigate further il let you know.
