My Gear Shift Selector Buttons on the steering have stopped working
![]() Anybody had a similar problem..... what do I check before going to the stealers and depleting my Frostie Funds... Tx
" Love the Sound of a V8....... All Day " *still wish it was a V10* 2002 S8 D2 F/L H & R Springs, Koni Coil Overs, Dastek Chip, Sport Exhaust, 19" S5 Rims, Solar Sun Roof (Cause we have Sun) and most of the Bells & Whistles. |
Is it a 3 spoke with tiptronic, or a 4 spoke multifunction with tiptronic ? - Its completely different wiring to check in each case.
Does tiptronic work off the gear selector ok ?
For parts enquiries and Forum User Administration please contact customer services directly, not me ![]() The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black ![]() 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
It is a 4 Spoke Multifunction with tiptronic....
Works fine on the gear Selector Shift.... Tx ![]()
Had a similar problem recently, they didn't quit altogether but they became intermittent.
It turns out to have been the steering wheel slip ring. I did try and test the slip ring by checking continuity from the input connectors to the output connectors but it seemed to be okay. In the end I decided to buy a used one from A8parts just to see if it would solve problem (a lot cheaper than paying Audi dealer an hours labour to diagnostic it and a brand new part just to test it) and hey presto paddle shift working again. I think the only way to narrow it down may be to do continuity check between loom connector on steering column to the loom connector on side of main gear selector. Since these connectors & loom are static they are less likely to have deteriorated, wheareas the slip ring is in effect a 'moving' loom and will be subject to wear and tear. As I said continuity check on the slip ring turned out to be misleading as it seemed to be okay. If you look on Audipages you'll see photos of the tiptronic loom connectors. Be careful when working in this area as the airbag connectors are there too Just an additional note - it also co-incided with the airbag light illuminating - this was a strong indicator that the slip ring was failing. Slip ring failure / deterioration is a common problem with older Audis & VWs. Do any of the other multifunction buttons on wheel 'misbehave'? |
Big Up for all the Info....
![]() It is def an intermittent issue.... works some times and not other times.. So Ur observation regarding the Slip Ring sounds spot-on. I have ELSA so will do a little research before attempting DIY fix. All the other buttons work 100's. Just as an aside I had the same issue on my Cab and eventually found it was the magnets/switches under the gear lever that needed cleaning. Problem sorted.
