Old 27th October 2011, 03:57 PM
tobes49 tobes49 is offline
The Aux air pump works with the engine ECU start up to provide an over rich mixture and late ignition timing,
This means the mixture is still burning as it leaves the engine, mix in some fresh air from the air pump and this gives a controlled burn in the exhaust which heats the cats up very fast.
This is why they sound tinny and use lots of fuel on start up.
Unless you have the over rich mixture and mapped out of the ecu, There no point in removing the air pump as this will kill the cats faster by dumping unburnt fuel into the cats
Old 30th October 2011, 08:31 AM
Thanks Tobes, good point.
Would 100 cell cats be more resistant to unburnt fuel during start up? I presume this fuel will get burnt eventually and 100 cell cats have less resistance to gas flow possibly allowing more of the unburnt fuel to flow past them into the rear of the exhaust?
Although I guess if I'm already going to someone to get the DTC mapped out may as well change the start-up fuelling map.
Old 16th November 2011, 09:06 PM
ok what happens if you decat the car ? do i still need the secondary air pump ? or would this be mapped out along with the over rich mixture at start up ? and lambda ?
Old 16th November 2011, 10:00 PM
You can map that out, speak to A8 Doc on here.
