Old 1st December 2011, 07:31 PM
tonyt102's Avatar
tonyt102 tonyt102 is offline
Sorry, they're 18"s. I was quickly trying to answer on my iPhone at work
Got underneath tonight and it looks like the hub is different as the calliper and carrier are bolted on from the side, not the back like the brembo. I've taken a picture. So, next question... will the newer Brembo compatable hub swap over?
Cheers for the replies.
Old 1st December 2011, 08:49 PM
take a look at THIS thread from when Oli upgraded his brakes and had to change hub carriers - sounds like you may have the same issue?
Old 1st December 2011, 09:06 PM
tonyt102's Avatar
I read that earlier actually and I think you're right. I've enquired about a price for the callipers, rotors and hubs. From reading a few other things, it would appear that the hubs are the same apart from calliper mount so should swap straight over.
Old 2nd December 2011, 08:21 AM
As Neil says, looks like you need to follow the same route as Oli, good thing is it's all 'plug and play' under there for the repacements
Old 2nd December 2011, 05:04 PM
tonyt102's Avatar
Just negotiated a really good price for both calipers, hubs and rotors, rear door cards inc blinds and rear shelf with elec blind and switch. It's a cash deal so its a 6hour round trip on Wednesday.
Old 2nd December 2011, 05:11 PM
Do you want to meet up there, I might go check out seats, it's only 15 mile drive from me.
Old 2nd December 2011, 05:25 PM
tonyt102's Avatar
Sound like a plan. I'm going to try and set of pretty early as I've got stuff to do in the afternoon so aiming to get there for around 11.30ish.
