Old 5th December 2011, 07:18 PM
Don't think so.
I just used to ignore mine until "I" thought it was the correct time for a service, it only stays on briefly.
Old 5th December 2011, 08:08 PM
Originally Posted by B@fink View Post
which now begs the question...can it be reset without VAG-COM?
Yes it can-that is how it is being reset, will look up how tomorrow if nobody else does it before that. There is also some trick how to reset it with knobs on instrument panel on some cars- might try to search on goggle.
Sorry, I read it as if it can be reset with VAGCOM in hurry. On some cars it can be reset without and on others not. Like pointed out below.
Old 5th December 2011, 09:07 PM
Well this isn't definitive, but:
http://www.audiforum.ca/showthread.php?t=34498
says:
How to reset Oil & Service light without a diagnostic tool
A8 1996-2006 Requires diagnostic tool.
Old 6th December 2011, 09:00 AM
christhompson's Avatar
and Gendan offers this for resetting the fixed service interval without tools
http://www.gendan.co.uk/article_6.html#audi_a8_1994
Old 6th December 2011, 09:50 AM
You have 1996 car right?
1.Connect to dash in VCDS
2. Select adaption
3.Use channels
5- oil change service, in 1000km, normally 15 for 15 000km
6- distance till inspection service 1, enter as above but normally 30 for 30k km
7 - time in x10 days till inspection service 1, normally 36 for 360 days
8 - time for inspection service 2 in days x10, normally 73 for 730 days
The value in those channels will show distance/time remaining. Enter new value, test and save. This will be less then values above if service was done a while ago so enter appropriate value to as much distance/time remaining.
Please note that distance used is in km not miles in all cars so do not forget to convert values before entering.
Old 6th December 2011, 08:53 PM
Nollywood's Avatar
'96 models can't be reset with the buttons.
Late '97 onwards can be reset with the buttons or suitable diagnostic equipment. There was a Euro bill that was passed circa '97, that all Euro vehicles MUST have the ability to have the service reset without using special tools, or visiting a dealership. In short, dealers weren't allowed to hold owners to ransome, clearing your service light for big bucks.
The same applied to early A4, you can't reset the service indicator with the buttons, while '97 onwards can be reset manually.
Old 7th December 2011, 05:53 PM
B@fink B@fink is offline
well mines a '98 and it won't reset from the buttons!
Old 7th December 2011, 08:34 PM
Nollywood's Avatar
Interesting. My '96 4,2 QS wouldn't reset via the buttons, my '98 S8 would. I serviced it twice whilst I owned it, and cleared the service via the buttons.
