Old 7th December 2011, 04:50 PM
Default Oh no, gearbox woe?
Strange series of events, but here goes.
A couple of days ago, I noticed a faint hum/whine at low speeds on over-run and, I think, when turning right, that appeared to be coming from the front nearside. But after a few miles, it went away. But same again this morning.
Then, at lunchtime, there was a similar but louder noise when I engaged reverse (even when not moving) and it continued until I changed gear. Tonight, when I left work there was no noise, but it was back again when I got home and engaged reverse.
All other gears are fine and changing is smooth.
Any ideas folks?
Old 7th December 2011, 04:58 PM
I had that once when the gearbox fluid was low. Normally, it warms up and expands, explaining the noise going away after a while.
Not sure it helps with the problem being there when you got home and selected reverse though.
Maybe this colder weather has made a small shortage of fluid more obvious as its contracted slightly ?
Old 7th December 2011, 05:46 PM
I'd maybe suggest a trip to A4 on the way to work tomorrow Sounds like low fluid.
Unless it's the F(?) seal going which kills reverse on the FL boxes.
Old 9th December 2011, 11:38 AM
Well, I took it in to A4 Audi and on the way, every time I drove it through standing water, the noise came back!
But yesterday, they couldn't get it to make a noise at all. So they tried it from cold this morning and reckon it's the power steering pump. They've changed the oil, but the noise persists, so I'm waiting to hear if they can get a new pump and fit it tomorrow morning.
But why would the power steering pump make a noise in reverse gear and on over-run?
Old 9th December 2011, 02:56 PM
Reffro Reffro is offline
Don't forget the recent clogged filters in the reservoir debacle....
Something about the little filter in the power steering reservoir causing noise, not a failed pump.
Old 9th December 2011, 04:55 PM
Andy at A4 Audi said the filter was clogged with metal particles, so he reckons the pump is duff. I don't recall the thread about the filter making a noise.
Old 9th December 2011, 06:06 PM
I'd rather it was that than a gearbox!!
Old 10th December 2011, 09:54 AM
I had a similar thing in my D2... Was headed for a new rack when I cleared it out and had no re-occurence.
