I have all sorts of annoying creaks that appear to come from my headling (02 D2) when as the car body flexes over bumps etc., but despite my best efforts I cannot track down he precise cause or location. I tried screwing down the sunroof frame a bit harder - no difference. Does anyone know a possible cause of this or can anyone provide me with the complete procedure for removing the headlining so that I can find the source and refix everything securely?
Thanks. |
Definitely headlining? I sometimes get creaks from the door trim and a bit of silicone spray sorts that out.
My steering column has a squeak from time to time that bugs me...
One problem with such a quiet well insulated car is you hear all the tiniest rattles inside but none of the external noises of impending doom. My gearbox/pump/TC noises were almost impossible to hear inside but soon as you opened the door it was bleeding obvious there was something wrong. |
Ian@A8parts will be around soon and he has removed and refitted several headlinings. I'm sure he will be able to help.
Mind is certainly from the roof area - seems to be just above the passangers head.
Checked the sunroof seals?
Could still be the headlining... You don't have a roof-mount dvd screen do you? |
No roof-mounted DVD--I've got a mortal antipathy to in-car DVD players.
I'm now certain that the noise is coming from the area between the front edge of the sunroof and the front edge of the passenger sunvisor. If I push up on that area it stops the noise. Is there anything particular in there that could be moving? Anything I should tighten up? If not, does anyone know the procedure for getting into that area? Thanks |
Welcome S8 Alan glad to have you along. Why don't you post a bit about yourself with some photos of your 8 in the introductions section. Be great to se you at one of the events this year..
