Old 27th July 2009, 12:58 PM
Reffro Reffro is offline
Default Auto Dimming Rear View Mirror
Practically the only thing my car wasn't fitted with and its one thing I really like. What's involved in retro fitting the auto dimming mirror? Is it even possible and what is the likely cost? Help please......
Old 27th July 2009, 04:09 PM
ChriS8 ChriS8 is offline
Hi.
Is your car a 1994 or 1995??
Chris.
Now playing: Bloodhound Gang - Screwing You On The Beach At Night
via FoxyTunes
Audi S8 manual, 1996 <- much fun
Kawasaki ZX9-R 2001 <- much more fun
always remember:ficken!
Old 27th July 2009, 06:27 PM
2002 s8
Old 30th July 2009, 09:06 AM
Its not too tricky....
The autodip interior mirror has simple + 12 supply, ground and connection for reverse (so it turns off when you select reverse) - It also has an output that can be used to drive the exterior door mirroring dipping too if you want that...
Old 29th October 2009, 04:29 AM
GlynH GlynH is offline
Hi Ian,
Hope you're well...it's been a while...
Quick question for you - one of the first things I did when I bought my S8 nearly 3 years ago now was to buy & fit the auto-dipping mirror - well along with a switch or two to replace those boring plastic covers.
I never did get round to wiring in the mirror and was thinking I needed the harness for it.
Looking at your post above it would appear that I might be able to take the +/-12v from the interior light - ignoring the reverse signal of course but at least it would save me squinting when some pillock comes up behind on full beam!
Would you happen to know what colours on the auto-dipping mirror wiring correspond to +/-12v please?
Can't remember what colours are in the mirror harness but will feel a little embarrassed if it turns out to be red/black!
Thanks & regards,
-=Glyn=-
Old 23rd April 2010, 03:52 PM
Night Train's Avatar
I'd go along with this one.......... and 'bump' it
Anyone know the wiring for an auto dip pre facelift, my 'new' mirror has 3 wires
Black with Blue trace, Brown, and Blue with Red trace, and best place to take feeds from?
Thanks
Other vehicles
Oh Yes....... The '98 PF S8!
Old 27th April 2010, 08:51 PM
Thanks
Black with blue trace = ignition + 12v
Brown = Ground
blue with red trace = Reversing feed
There is no easy place to get the feeds from in the roof as the interior lights arent ignition controlled, and the sunroof power feed is controlled by the central locking module as it works for a short time after ignition is off so that you can still close it, and it can be done from the remote.
If it were me, I'd pop off the passenger side A pillar trim and run cables up there directly from the relay box under the passenger footwell carpet. I would imagine that you will likely be able to tap the reverse feed from down there somewhere too. It will be blue/red and runs the length of the car to the boot down the sills, most likely the passenger one....
Hope that helps...
Old 27th April 2010, 09:21 PM
Thanks for the heads up Ian,
That's fantastic, I'll get stuck into that over the weekend. My immediate project is iPod & USB integration which I may do tomorrow if the weather's ok and the ordered parts arrive in time. (Dension Gateway 300)
I'll report back if this is successful, failing that I guess I'll be looking at possibly upgrading the head unit (something OEM Audi) not sure quite how radical to go though.....
Other vehicles
Old 21st December 2011, 11:04 AM
I know it's an old thread, but did this ever work?
The lack of an auto-dim mirror on my 1998 PF S8 has always niggled!
I've even upgraded my similar-vintage Ford Focus with one which is nice; it was pretty easy - just needed to run a longish single wire to find a suitable switched 12V supply - took earth from the interior light.
(took 12V from the night-lighting connector on the back of the radio in the end as it was easy to identify and access)
Old 21st December 2011, 06:45 PM
Nollywood's Avatar
It works great - my pre-facelift A8 4,2 QS had auto dim rearview mirror, however, my pre-facelift S8 didn't. I ran my feed direct from terminal 15 (via the fue / relay panel in the passenger side).
