Old 21st December 2011, 07:05 PM
Originally Posted by Nollywood View Post
It works great
Excellent, sounds like a New Year pressie for the car....
But how easy is it to mount?
My S8 mirror is just on a short stalk glued to the screen, which obviously I don't want to damage.
There's one listed by A8parts on eBay but it looks like it's mounted on a stalk:
http://www.ebay.co.uk/itm/Audi-A8-D2.../130585974107?
(electrics I'm sure I'll cope with having already done the Focus )
Old 25th December 2011, 01:16 PM
Night Train's Avatar
Hi HP......
The mirror is still glued to the screen in the same way, the 'stalk' is a sort of 'conduit' for hiding the wiring to the mirror up to the headlining (felt padded) that rests against the screen.
HTH
Other vehicles
Oh Yes....... The '98 PF S8!
Old 26th December 2011, 10:10 PM
Alcantara please.
Thanks for the info, Carl from A8parts said similar in an eBay message.
Old 27th December 2011, 02:45 PM
I think my S8's a little 'police-specced', when compared to yours
Other vehicles
Old 27th December 2011, 10:34 PM
the sunroof power feed is controlled by the central locking module as it works for a short time after ignition is off
How is that a problem; the sunroof seems an ideal power source?
Or will it upset the module in some way.....
Old 3rd January 2012, 12:58 PM
No, it will probably work fine I guess. It would just bug the crap out of me knowing that I'd cut corners to wire it up, I'm a bit anal when it comes to wiring things up the 'factory way'
Old 6th January 2012, 09:44 AM
Black with blue trace = ignition + 12v
Brown = Ground
blue with red trace = Reversing feed
Well my nice mirror arrived today from A8Parts.
But it has 6 wires in the lead, including the 3 above:
Brown
Blue with red trace
Red
Yellow
Green
Any ideas anyone what Red/Yellow/Green are for?
And a very important point - how do you remove/remount it?
Looking at the end of the mounting arm it has some sort of clip, but no obvious release mechanism.
Not being able to see the "button" it mounts on I've no idea - is there a release button or fixing screw there or do you just pull or twist it off?
I certainly don't want to risk damaging the windscreen!
Edit: Found several comments online saying twist the stalk 90 degrees anticlockwise to unlock. Can anyone confirm before I risk cracking the screen?
Also, what's the best way to get into the sunroof control panel to get some power; it doesn't obviously come off simply so there's presumably more than clips holding it all up there.
Last edited by HPsauce; 6th January 2012 at 06:01 PM. Reason: More information found online.
Old 6th January 2012, 10:57 PM
Nollywood's Avatar
Twist 90 degrees and withdraw to remove is correct.
The extra wires, it's been a while I fitted an auto-dim mirror to my old '98 S8. The blue with red trace is illumination (instrument illumination).
I actually fitted an auto-dim from a 2005 Audi Allroad, it had a digital compass in one corner, pretty neat.
Old 6th January 2012, 11:31 PM
It's about 45 dg anti-clockwise on PF cars to undo it but take care. Cannot help about wire atm
Old 7th January 2012, 10:24 AM
Well I've verified the 2 important wires:
Brown = Ground
And tested it works by jury-rigging the lead to a 12V DC wall-wart and covering the sensors appropriately.
Any thoughts from anyone on how to get safely into the overhead lighting/sunroof control area and what to look for?
I'm not bothered about the reverse feed at all; I didn't connect that on the unit I fitted to my Focus and don't ever miss it.
(tend to use windows, side mirrors, eyes and brain, assisted by the rear parking sensors )
