View Poll Results: Cool or Not Cool
Cool 16 100.00%
Not Cool 0 0%
Voters: 16. You may not vote on this poll
Old 5th February 2012, 07:46 PM
Night Train's Avatar
47p2
In partial answer to your question -
Mainly engine mods
4BBL Holley (manual choke) on Offenhauser 360 inlet manifold & heat insulator. matched manifolds
Full balance, lightened & nitride 10/10 R/G on crank
SD1 conrods (instead of the rubber P5B ones)
10.5:1 +020 pistons (forged)
Spike Anderson (of Samuri fame, for those that remember him - what a bloke!) Cylinder head rework in exhaust finish. - matched chambers adjusted to run on 4 star (premium unleaded really, being ali heads must have steel inserts).
Steel duplex vernier timing gears
Crane H200 Cam
Crane anti-pump lifters (will rev to 7k)
Lumenition
Stainless flexi fan (sounds great)
Baffled sump
biggest problem is that it destroys gearboxes (BW35 Jag 4.2 internals) & diffs (same as Range Rover (3.54:1) if showing up the local boy racers a bit too often..........
Other vehicles
Oh Yes....... The '98 PF S8!
Old 6th February 2012, 10:43 PM
47p2's Avatar
47p2 47p2 is offline
Originally Posted by Night Train View Post
47p2
...biggest problem is that it destroys gearboxes (BW35 Jag 4.2 internals) & diffs (same as Range Rover (3.54:1) if showing up the local boy racers a bit too often..........
Funnily enough, as I was reading down the list I was thinking about the gearbox. Sounds like an awesome set-up
