Go Back   A8 Parts Forum > General Natter > House and Home DIY
House and Home DIY Everything at home. Building, Renovating, DIY, green initiatives, mowing the lawn. Anything goes
Old 10th February 2012, 10:04 PM
http://www.facebook.com/media/set/?s...3&l=57aadd0d30
And here it is up until mid Decemeber, when all hell broke loose and updating facebook was the furthest thing from my mind.
I took photos, but only finished sorting them last week. Need to pick a few choice ones to add to the album to finish it off.
Old 10th February 2012, 10:06 PM
47p2's Avatar
47p2 47p2 is offline
I take my hat off to you Ian, that's one hell of a task to take on. I feel your pain but I think yours was worse then mine
Nite Blue 3.0L SE Quattro
Old 10th February 2012, 10:21 PM
Thanks for insulation writeup Ian.
I've accomplished a project of comparable scale once in my life, but not in the UK. Took 1.5 years.
Very impressed with wiring photograph. Are these Ethernet cables? Looks like data center room.
Old 10th February 2012, 10:25 PM
The bulding project was tough, as I'm sure was yours. They both involved sand, cement, concrete, blocks, mortar and beloved buliding regs. Thats as fundamental as it goes..
The biggest trauma for me was the fact that I had to park me, and my whole family in some shoebox rented accomodation whilst it went on.
The drain it placed on daily life, routine, having space for the kids to play, birthday parties, social life, heck we didnt ever have TV - That was the bit I really, really overlooked.
We're past that now fortunately.....
Old 10th February 2012, 10:41 PM
I bought this house in 1999, first thing I did was to rip up floorboards and install 4 x Cat5 sockets in every room.
My 2010 rebuild needed a bit more than that. So every wire and pipe was ripped out, I mean everything.
The main component in the wiring spaghetti is power cables. Every power socket in the house is wired individually.
I'll say that again, as I know I'm prone to typos.
Every single plug socket in the house, is wired individually.
My concept is simple. Every socket in the house ought to be able to be mains powered, ups powered, or off.
UPS powered for devices which are important to keep running, eg computing, security etc, (but maybe bedside alarm clock, or comfort features such as TV if you're in the middle of watching something. Lighting will be UPS run, but will dimm automatically to reduce power draw and increase runtime)
Off - For devices which dont need to be on, and thus power can be saved. This also integrated with the solar PV panels. So, turn on the battery charges for the kids toys when its sunny.... Turn them off again, when its not.
For example, the system we've designed (but I add, not fully implemented yet) doesnt have light switches, it has smart switches.
So, every light point in the house doesnt have a 1mm or 1.5mm twin and earth, it has a cat 5 lead.
At the moment, all light switches are regualar mains light switches, but connected with Cat5 wires feeding back to a central point.
In time, they will be replaced with momentary up/down switches (MK do some, but they're a bit hard for the kids to press).
So, imagine. 1 switch at the front door.
Up - Light on in the hallway
Down - Light off in the hallway
Hold it down for 5 seconds, turns off hallway light, every light in the house and every non-essential appliance that its plugged into a socket deemed unimportant, and sets the house alarm for you to exit.
Up for 5 secs - something else
up twice quickly - something else again
The key is to make it 100% useable for average joe bloggs visitor, but for me and my wife to have extra functionality that we know about. Most home automation systems are too complication for visitors and friends....
Also very energy efficient, as we will turn off all the stuff kids leave on at a press of a button
The main room has over 70 lights. Each wired seperately. Each will dim and fade seperately. Only the lights you *need* on, need be on.
The outside security lights - All seperately wired, and will be dimmable. Who needs 500w of Halogen? normally, 100w is plenty to see your way to the door. 500w is when you drop your keys or lose something.
Of course, every room has Cat 6 too. Most sockets are arranged in a 2 x 2 pattern, 3 mains sockets, and 1 double Cat 6 outlet - In every corner of every room.
A normal house has maybe 1, or 2 distribution boards for the mains.
I have 9. Triples. Thats 27 distribution boards. (!)
But fundamentally, everything is wired back to just 1 place, so everything can be intelligently controlled from there. Its a big big dream, but becoming reality. The important thing is that I 1st fixed all of this lot before the plaster went on, so now I get to finish it at my leisure.....
Old 10th February 2012, 11:43 PM
I take my words back Ian. In terms of electrical systems my project was at least 27 times less complicated since I ended up with only 1 distribution board.
I'm not that obsessed by electrical systems though. I'm obsessed about size of rooms and height of ceilings.
We are now slowly looking for a house to buy and the first problem I faced is that UK houses all have low ceilings. Even houses with big rooms (which are already rare) have low ceilings and that kills that airy feeling of full size house. I don't understand that. Quick search revealed that it is impossible to buy contemporary house with ceilings at least 3 meters high. You can easily buy full size car (A8) in this country, but you cannot buy full size house. Only rare old houses (i.e. victorians) come with high ceilings, but they usually need serious renovation, which I don't want to do second time in my life.
Old 11th February 2012, 12:44 AM
I've been here when it was work in progress, that was ages ago! Looking forward to seeing completed photos, it sounds very techy and very you.
Old 11th February 2012, 07:05 AM
Do you have a 360 degree Camera i see outside the house ? more detales please
Old 11th February 2012, 05:43 PM
Most importantly - When is the housewarming party? Have not received my invitation yet. Must have been lost in mail
Old 11th February 2012, 05:59 PM
There is more than 1
Yes, full 360 degree night vision, but they arent the backbone of the security, they are just for investigation, or close monitoring of special things, eg a particualar car on my drive etc.
Full coverage of the house is provided by additional static tamper proof domes, Nite Devil night vision, all integrally cabled into the house - no wires to snip - and all CCTV is ups protected.
You think you're ever gonna get near my house, let alone my car, without me knowing.... dream on
