Old 14th February 2012, 01:48 PM
would it work if i installed the standard centre box back on and kept the rest from the back ok with the quads or is it the back box that takes away the drone ?
Old 14th February 2012, 03:21 PM
I don't know mate and i'm not sure how to work it out except trial and error.
Old 14th February 2012, 05:14 PM
its so hard living in the sticks when there is nothing around hear i have to travel a minimum of 80miles to get any fabrication done, im just wandering what makes the A8 or S8 so quiet is it the back box or the centre box that takes away the drone
Old 15th February 2012, 07:33 AM
How many cylinders fire in one revolution on the 4.2 ? im trying to work out the engine rpm x number of cylinders fireing in one revolution/60 or 2000 in order to work out the frequency witch will= the lenth of any resonators i put on, for example 133hz would be 2.25"x28" at any bend or shape so long as its capped
Old 15th February 2012, 08:06 AM
Surely it's a 4-stroke V8 engine so half (i.e. 4) fire on each revolution?
So at 1500rpm you get 6000/60 = 100 fired per second.
Old 15th February 2012, 08:35 AM
just spoke to mike and he is fairly sure the problem or rather the cure is to re-install the centre box as that contains the resonating chamber and hopefully that will solve my problem
Old 19th February 2012, 08:51 PM
Well its all done now its almost back to standard but of course i have kept the quads on there so there is no drone any more only a slight one very quiet again but when you give it some beans its a lovely V8 sound im in the middle of getting pipercross to make an induction kit for the S8 and A8 4.2 engine should be with me on tuesday or wednesday next week so i will report in with the result i think it will sound nice with a roar to it but the advantage is of course that you can keep it quiet when driving and after 4k rpm it will bring the engine to life a bit thanks for all the advice on this
