Old 16th February 2012, 12:57 PM
gapthree3 gapthree3 is offline
Default GruvenParts
Just recieved my 1" arms from www.gruvenparts.com and replaced the broken arm on the RH (as you look at it) inlet vacum pod. Easy to do, after taking off the engine cover. Just pushfit the old off & on with the new, all done by hand. Took her for a spin and noiced quite a difference on my now 190K 2002 S8. Between 2,000rpm & 4,000 there is definately more torque and so the gbox does not need to kickdown as much. All in all a major performance improvement for £80. I'll see if it improves the 23.6 mpg average and post any changes. Well worth checking out if yours have snapped as most do and go undetected.
Old 16th February 2012, 07:58 PM
do the 3.7 40V V8's have these arms as well, or are they only the domain of the 4.2?. At 175,000 miles should I be checking.
Old 16th February 2012, 07:59 PM
I expect it does - just pull the top engine cover off and they're visible on the front of the engine - couple of bellows is all it is
You may even be able to use the 2" arms advertised recently?
Old 17th February 2012, 01:01 AM
Yes they do have them, and as Adrian suggests they are longer than the S8 ones, but you won't be able to use the 2" arms advertised recently because I have already acquired them!
Old 17th February 2012, 03:35 AM
71camaro 71camaro is offline
I'm averaging 17.9 mpg
Old 17th February 2012, 07:45 AM
I've averaged 14.9mpg overall since I started making a note of fuel fills last March.....
Tank average ranges from 12 to 20.2mpg - that's calculated average, not DIS lies!
Old 17th February 2012, 11:34 AM
At least you are not paying US$7.56 per US Gallon.
Old 17th February 2012, 02:02 PM
SilverS8 SilverS8 is offline
Or $10,36
2003 Daytona Grey RS6
2000 Silver S8
2005 A6 1.8TQ Premium
Old 17th February 2012, 06:39 PM
frankow's Avatar
frankow frankow is offline
I have a set of Gruvenparts S8 1" arms available if anyone is interested, see For Sale section.
Brand new, not even opened.
Old 18th February 2012, 10:42 AM
I checked mine today, the plastic ones are fine and still in one piece. I also checked their operation, and both seem to move correctly so it seems I am all good.
