Old 19th February 2012, 07:26 PM
Default This is the right oil?
This is correct isn't it?
Old 19th February 2012, 07:45 PM
Don't think it is Mike - I believe the spec required is a 5w30 although mine runs on 5w40. Think the one in your link is a semi-synthetic anyway?
I've run 5w40 Castrol Edge for the past year, but just swapped the A6 onto Fuchs Titan Race Pro S in the same grade as it's supposedly a better quality product, as well as being a bit cheaper as sold in 5 litre cans. The S8 will be getting the same in a few months.
Last 2 lots of oil bought from Opie
Old 19th February 2012, 08:22 PM
That would be this one then?
Old 19th February 2012, 08:34 PM
I think any of them will do, just check owners manual what specification it says. I do not have it to hand but I think it was 500.00. Viscosity is not really that important. Higher viscosity will be better for hot weather and race use, lower viscosity better for cold weather and fuel economy.
Old 19th February 2012, 09:22 PM
my service book says 503 00 or 503 01 - the 01 version is for longlife service but fine if changed annually.
Fuchs isn't approved to VAG specs, but I'm not bothered by that.
Looking at what's available the spec generally relates to a 0w30 grade, but it does vary a bit and i'd avoid 0w anthing.
Any quality synthetic should be fine - I opted for Fuchs on the recommendation of S/RS owners but would buy the Castrol Edge again.
I gather none of the Synta branded oils are what's used by dealers, bizarrely!
Old 20th February 2012, 07:05 AM
My recommendation is use Quantum Longlife III 5W-30 oil which is good for up to 2 years/ 18000miles but still change it yearly if you do less miles for easy road use or use Castrol Edge 10W-60 if you push it hard or use it on track often.
Old 20th February 2012, 08:41 AM
I'm due oil change, is this a better price than TPS?
Old 20th February 2012, 10:40 AM
TPS won't sell to me but it would be cheaper to by 8ltrs from Audi than 10ltrs from this guy.
Old 20th February 2012, 02:05 PM
After further discussion and a request for a little bulk discount I can get it for £4.60 per ltre for 10ltrs!
Old 22nd February 2012, 01:50 PM
I've been ringing around for prices, i've been giving the same part number that is ZGB 115 QLB 005 11 and the results so far are:
TPS = £19.35
Audi (Exeter) £18.85 +VAT
Audi (Barnstaple) £28.?? + VAT i didn't hear the pence as i was laughing
Audi (Taunton) we don't stock that sir but it'll be £25 - 30 + VAT
Audi (Plymouth) £19.35 + VAT
Audi (Portsmouth) £25.16 + VAT
Exeter, Barnsatple, Taunton and Plymouth are owned by the same group too.
