Old 26th February 2012, 08:08 PM
Default Can I change front brake hose myself :)
Hello All,
Last time I passed my MOT with the following advisory: "Nearside Front Brake hose slightly deteriorated (3.6.B.4d)". Interestingly, Reading Audi didn't notice this problem when I changed my callipers a year ago.
So I decided to change brake hose. Is it easy to do? I think I have all required tools, but I've never done this before...
Or should I go to Audi? Anyone changes brake hoses at home?
Old 26th February 2012, 08:28 PM
47p2's Avatar
47p2 47p2 is offline
It's a straight forward enough job if you know what you are doing, but you need to make sure you don't end up getting air into the hydraulic system. Any garage will be able to change it for you for not a lot of money if you are unsure.
My advice when it comes to brakes is leave it to the experts if you don't know what you are doing
Nite Blue 3.0L SE Quattro
Old 26th February 2012, 08:31 PM
Thanks. Brake bleeding procedure is the procedure I've never done.
Will need to find good mechanic I can trust.
Old 26th February 2012, 08:39 PM
47p2's Avatar
Best left to someone who knows what they are doing then
Old 26th February 2012, 08:42 PM
It wouldn't surprise me if it wasn't picked up at the next MOT (unless the bloke doing it reads the advisories off the system from this year and makes a note to check it). Quite often it's just an opinion/note rather than a suggestion it's anywhere near causing you any problems.
Any decent independent garage should be able to sort - very little fluid should be lost and they only need to bleed that corner to make sure any air is removed from the caliper.
As you say, if it was bad when the calipers were being replaced you'd expect a call to suggest some new flexis would be a good idea.
I might get some braided hoses made up for mine when it needs one doing - got someone I know who makes the hoses for Morgan in braided stainless
Old 26th February 2012, 08:43 PM
I would do it myself, but I have all the tools. It's not difficult, but make sure you bleed the brake lines properly. Take of the brake line on the inner wheel arch first and pop some sort of cap straight on to stop the fluid running out. Remove and replace the line on the caliper. Then reconnect to the car and immediatly bleed the brakes.
You can do this with normal open ended spanners but I would urge you to buy a brake spanner and when loosening the bleed nipple us a socket to crack it. If it dosen't crack easily just use a bit of heat or a light tap with a hammer, Dont force it as it will sheer and you'll be in a world of hurt.
Old 26th February 2012, 09:42 PM
Thanks Conan. I guess brake bleeding should be done by two people. First is pressing the pedal while second operates the nipple, right? I don't have second person.
Need to find a good local mechanic I can trust. I think I need to see how it is done first.
Old 27th February 2012, 04:39 PM
Use a Gunson's eezibleed for one man bleeding,
Old 27th February 2012, 06:00 PM
Thanks Conan. Great stuff. Purchased parts from Audi today.
Old 14th March 2012, 08:04 PM
adjuster adjuster is offline
Ah, having a power bleeder is the way to go on this. (Uses compressed air to "suck" all the old fluid out. Just keep the tank at the master cyc. full, and it's going to remove all the air, and old fluid in the same process.)
Mine was about 75.00 USD, but I'm not sure what they run on your guys side of the pond. (But I'd have to say not much more.)
Especially since most of this stuff is made in China anymore.
To use the power bleeder is simple.
Just change out the line, you will need a bottle of new brake fluid too.
Just make sure the brake fluid tank is full, cap off/or on the side.
Then using a small 6 point, crack open the bleeder valve, and pop the hose on there, while applying air to the unit. (Creates suction.) This will suck out any old fluid and air at the same time. It takes about 90 to 120 seconds to pull out all the old fluid from the caliper and lines to the fluid tank.
Close the bleeder valve, and make sure your fluid tank at the master cyc. is filled up where it should be, and you are done. (Test drive, and confirm brakes work fine.)
I've done perhaps 50 cars this way in the past, since it's so easy, and any time I swap the pads even, I'll bleed the brakes, and put in fresh fluid this way.
