I don’t know if this is actually in immobiliser issue or not but I’ve now had 2 instances of the car struggling to start. In both cases the car had been switched off when at normal operating temperature and then an hour or so later, when I try to start it, it struggles to stay running. The tick over is very slow so it barely keeps running and it’s reluctant to rev.
In both instances I switched it off and tried to start it again and it was the same. I get no immobilised warning light (the key symbol) and all the dash lights look ok but I suspected an immobiliser issue because the first time it happened I was loading the car with luggage and it passive armed itself so I thought maybe the ECU was immobilised (although the engine did start and run, albeit badly). Also, the car runs lpg and when you switch on the ignition the led lpg gauge normally illuminates but this time it didn’t. I thought maybe the ignition feed was isolated and so the lpg ECU had no power and hence the gauge didn’t light up. The power wiring for the lpg ecu isn’t exactly obvious, it has a direct earth and live off the battery (both of which were ok when tested with a meter but without a load of dismantling, I couldn’t trace an ignition feed and there was no sign of any wiring that had been added in which would give a clue where the ignition feed is taken from. I was pulling off trim panels and checking fuses and generally fiddling and I tried locking and unlocking the car a few times and eventually, for no obvious reason, it started and ran fine. Last night it did the same thing, so I just locked it, left it alone and a couple of hours later, it started first time. So far it’s been a minor inconvenience but I know it’ll be back to cause more bother later. Can I discount the immobiliser as the cause as there’s no warning light (and I did a code scan the first time and got no errors). I think having 2 ecu’s makes things more complicated and this hasn’t helped with my long running misfire issue which for the time being is ok on lpg but not great on petrol. The car is a 2000 S6 40V, when it’s running right it’s brilliant but these constant niggling problems are starting to annoy me. |
If its an immobiliser problem, the engine will start perfectly, then cut out abruptly after a second or so with the immobiliser light flashing - You dont seem to have this.
In the past I've seen LPG systems installed with the ignition feed taken out of the plenum chamber - Big plastic box on passenger rear side of engine bay housing all the ECU's. Sequential LPG systems sit in the way of the petrol injectors, so if the LPG system is losing power, it will knock all fuel supply out. I think you're on the right lines by investigating that further......
For parts enquiries and Forum User Administration please contact customer services directly, not me ![]() The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black ![]() 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
Cheers for that. I've just been reading threads oin the immobiliser issue and like you said, it looks like that isn't the cause.
The lpg system has a seperate harness that breaks into the petrol injectors, I think this is so the lpg ecu can stop the injectors firing and also make the petrol ecu think that it's actually still running on petrol. I'll have a look at tracing the wiring back from the lpg ecu connector that's in the plenum on the passenger side - it will have to get an ignition feed from somewhere. However, what if the ecu got it's main power directly from the battery and took an additional switching ignition feed from somewhere else - like a coil pack? From memory coil pack 8 has had one of the wires broken into and I think that goes to the ecu - this looks like a good starting point. |
