Old 28th February 2012, 08:02 AM
If its an immobiliser problem, the engine will start perfectly, then cut out abruptly after a second or so with the immobiliser light flashing - You dont seem to have this.
In the past I've seen LPG systems installed with the ignition feed taken out of the plenum chamber - Big plastic box on passenger rear side of engine bay housing all the ECU's.
Sequential LPG systems sit in the way of the petrol injectors, so if the LPG system is losing power, it will knock all fuel supply out.
I think you're on the right lines by investigating that further......
