Old 3rd March 2012, 12:42 PM
David,
Can you supply individual springs, for the 3.7QS. Not sure if they are the same as the 4.2 QS.
Old 3rd March 2012, 01:06 PM
You want a matched pair.
The reason it sits lower on one side could be because one of the springs were changed in past not both at the same time.
At least you need to get the spring with the same colour markings on it from the similar mileage car if changing just one spring and not just by the car model.
Old 3rd March 2012, 01:13 PM
Would these for example go on the 3.7 FL.
http://www.ebay.co.uk/itm/Audi-A8-D2...a#ht_901wt_902
Old 3rd March 2012, 01:22 PM
They should do but only way to know for sure is to check colour markings on yours and buy the ones with the same colour markings. Otherwise they could could be slightly stiffer or softer.
Another thing to take keep in mind is that many 8's are sagging a bit in rear so it might be beneficial to get slightly stiffer version if buying second hand
Old 3rd March 2012, 01:28 PM
Check the attached pdf for number of variations
Old 3rd March 2012, 01:30 PM
47p2's Avatar
47p2 47p2 is offline
False economy buying used springs, better buying a new pair, that way you won't have any problems for a long time. Buying OE parts from or TPS should not be much more than £100 a pair I would think
Nite Blue 3.0L SE Quattro
Old 3rd March 2012, 01:32 PM
Dealer price is £140 each
Old 3rd March 2012, 01:54 PM
Well it does look like a broken spring,
I just popped out and took a couple of quick pictures without removing the wheel.
The first one is the spring on the low side, and the second one is the good other side.
ID:	2906   Click image for larger version
Old 3rd March 2012, 02:13 PM
That does look broken. You can see 2 green dots on it in the picture so it is either 1 white 3 green or 1 white 2 green. If you buy one you need same colour coding from similar age of car.
Old 3rd March 2012, 02:27 PM
Originally Posted by david@a8parts View Post
The offside 'leg' of the fuel tank is around twice the size of the nearside but even so I have never noticed a difference in ride height between NS and OS with a full tank. I would have a look at the spring on the low side and make sure it is all in tact - we have seen some where a small piece of the top coil has fractured off thus reducing the ride height just a little.
I would agree with David - the springs can sometimes snap off at the seat end on the front and back - have you checked the seats to see if they're ok?
*oops posted before I caught up!*
