Old 19th March 2012, 05:44 PM
47p2's Avatar
47p2 47p2 is offline
Current Wheel Specs
Width 9" Offset 44 mm
New Wheel Specs
Width 8.5" Offset 35mm
Results
Inner clearance 15mm more (This means the wheel is 15mm further away from the suspension on the inside)
Outer position 3mm further out (This means your wheel will sit out 3mm further out on the outside edge) (would be a bit too much I think)
All this is assuming that the wheels are 8.5J rims
Nite Blue 3.0L SE Quattro
